Subject: Re: asyn bo record staying in INVALID DRIVER UDF
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 27 May 2021 16:12:51 +0200
Hej Ralph,
I think it is the same-
camonitor, second round:
IOC:m6-OpenClutch 2021-05-27 15:51:06.243006 Closed UDF INVALID
IOC:m6-OpenClutch.UDF 2021-05-27 15:51:06.243006 0 UDF INVALID
IOC:m6-OpenClutch.STAT 2021-05-27 15:51:06.243006 UDF UDF INVALID
IOC:m6-OpenClutch.SEVR 2021-05-27 15:51:06.243006 INVALID UDF INVALID
[snipped warnings because of multihomed]
And this is dbpr IOC:m6-OpenClutch 10
ACKS: NO_ALARM ACKT: YES ASG : ASP : PTR (nil) BKLNK: ELL 0 [(nil) .. (nil)] BKPT: 00 COSV: NO_ALARM DESC: motor DISA: 0 DISP: 0 DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x1030ca0
DSET: PTR 0x7fb1485072c0 DTYP: asynInt32 EVNT: FLNK: CONSTANT HIGH: 0 IVOA: Continue normally IVOV: 0 LALM: 0 LCNT: 0 LSET: PTR 0xf143d0 MASK: 0 MLIS: ELL 4 [0x7fb11802fb38 .. 0x7fb11802fc40]
MLOK: b0 e8 fa 00 00 00 00 00           MLST: 0
NAME: IOC:m6-OpenClutch                  NSEV: NO_ALARM
NSTA: NO_ALARM OLDSIMM: NO OMSL: supervisory ONAM: Open
ORAW: 0             ORBV: 0             OSV : NO_ALARM
OUT : INST_IO @asyn(MCU1,6)OpenClutch PACT: 0 PHAS: 0 PINI: NO PPN : PTR (nil) PPNR: PTR (nil) PRIO: LOW PROC: 0 PUTF: 0 RBV : 0 RDES: PTR 0xb6e100 RPRO: 0 RPVT: PTR 0x1030c70 RSET: PTR 0x7fb146f9e860 RVAL: 0 SCAN: Passive SDIS: CONSTANT SDLY: -1 SEVR: INVALID SIML: CONSTANT SIMM: NO SIMPVT: PTR (nil) SIMS: NO_ALARM SIOL: CONSTANT SPVT: PTR (nil) SSCN: <nil> STAT: UDF TIME: 2021-05-27 15:51:06.243005887 TPRO: 0 TSE : 0 TSEL: CONSTANT UDF : 0 UDFS: INVALID
VAL : 0             WDPT: PTR (nil)     ZNAM: Closed        ZSV : NO_ALARM
/Torsten
On 5/27/21 2:21 PM, Ralph Lange via Tech-talk wrote:
Hi Torsten,
On Thu, 27 May 2021 at 12:53, Torsten Bögershausen via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Asyn-Experts,
    I am chasing an interesting problem.
    For a motor, we have a clutch that can be opened under very
    special conditions, say service mode.
    We define it like this:
    The alarm seem to go away, if the record is processed one more time.
    (by disconnecting the IOC from the controller and re-establishing the
    connection).
    Is this a know phenomena ?
    Anything that can be done ?
How does the setup behave when using Channel Access?
(To see if it is a problem on the ASYN side or the QSRV side of the database.)
Cheers,
~Ralph
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Prev: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
