Subject: Re: asyn bo record staying in INVALID DRIVER UDF
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 27 May 2021 16:35:11 +0200
Hej again,
the alaram goes away, if the record is processed one more time.
We don't need to write to the PV, it is enough to disconnect-
and re-connect. Then the asyn callbacks will trigger, and the alarm
goes away.
This code:
IOC:m6-OpenClutchdevAsynInt32.c: static long initBo(boRecord *pr)
    devPvt *pPvt;
    int status;
    epicsInt32 value = 0xFFFFFFFF;
    status = initCommon((dbCommon *)pr,&pr->out,
processCallbackOutput,interruptCallbackOutput, interruptCallbackEnumBo,
        2, (char*)&pr->znam, NULL, &pr->zsv);
    fprintf(stdout, "%s/%s:%d %s status=%d\n",
            __FILE__, __FUNCTION__, __LINE__,
            pr->name, (int)status);
    if (status != INIT_OK) return status;
    pPvt = pr->dpvt;
    /* Read the current value from the device */
    status = pasynInt32SyncIO->read(pPvt->pasynUserSync,
                      &value, pPvt->pasynUser->timeout);
    fprintf(stdout, "%s/%s:%d  %s status=%d value=0x%X\n",
            pr->name, (int)status, value);
    if (status == asynSuccess) {
        pr->rval = value;
        return INIT_OK;
    return INIT_DO_NOT_CONVERT;
gives this prints:
../../asyn/devEpics/devAsynInt32.c/initBo:1203 IOC:IOC:m6-OpenClutch status=0 ../../asyn/devEpics/devAsynInt32.c/initBo:1211 IOC:IOC:m6-OpenClutch status=10 value=0x0
So that the poller() hasn't been able to talk to the controller (yet).
And later, when the callback comes:
static long processBo(boRecord *pr)
    devPvt *pPvt = (devPvt *)pr->dpvt;
    int status;
    fprintf(stdout, "%s/%s:%d %s pPvt->newOutputCallbackValue=%d\n",
            pr->name, pPvt->newOutputCallbackValue);
    epicsMutexLock(pPvt->devPvtLock);
    if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
        /* We got a callback from the driver */
      fprintf(stdout, "%s/%s:%d %s pPvt->result.status=%d\n",
              pr->name, pPvt->result.status);
        if (pPvt->result.status == asynSuccess) {
            pr->rval = pPvt->result.value;
            pr->val = (pr->rval) ? 1 : 0;
            pr->udf = 0;
../../asyn/devEpics/devAsynInt32.c/processBo:1225 IOC:m6-OpenClutch pPvt->newOutputCallbackValue=1 ../../asyn/devEpics/devAsynInt32.c/processBo:1232 IOC:m6-OpenClutch pPvt->result.status=0
and here udf is set to zero.
But the alarm stays.
I don't know if this is a possible issue in base, asyn or somewhere else.
BR
/Torsten
On 5/27/21 4:12 PM, Torsten Bögershausen via Tech-talk wrote:
Hej Ralph,
I think it is the same-
camonitor, second round:
IOC:m6-OpenClutch 2021-05-27 15:51:06.243006 Closed UDF INVALID
IOC:m6-OpenClutch.UDF 2021-05-27 15:51:06.243006 0 UDF INVALID
IOC:m6-OpenClutch.STAT 2021-05-27 15:51:06.243006 UDF UDF INVALID
IOC:m6-OpenClutch.SEVR 2021-05-27 15:51:06.243006 INVALID UDF INVALID
[snipped warnings because of multihomed]
And this is dbpr IOC:m6-OpenClutch 10
ACKS: NO_ALARM      ACKT: YES           ASG :               ASP : PTR (nil)
BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00            COSV: NO_ALARM
DESC: motor         DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0x1030ca0
DSET: PTR 0x7fb1485072c0                DTYP: asynInt32     EVNT:
FLNK: CONSTANT      HIGH: 0             IVOA: Continue normally
IVOV: 0             LALM: 0             LCNT: 0             LSET: PTR 0xf143d0
MASK: 0             MLIS: ELL 4 [0x7fb11802fb38 .. 0x7fb11802fc40]
MLOK: b0 e8 fa 00 00 00 00 00           MLST: 0
NAME: IOC:m6-OpenClutch                  NSEV: NO_ALARM
NSTA: NO_ALARM      OLDSIMM: NO         OMSL: supervisory   ONAM: Open
ORAW: 0             ORBV: 0             OSV : NO_ALARM
OUT : INST_IO @asyn(MCU1,6)OpenClutch   PACT: 0             PHAS: 0
PINI: NO            PPN : PTR (nil)     PPNR: PTR (nil)     PRIO: LOW
PROC: 0             PUTF: 0             RBV : 0             RDES: PTR 0xb6e100
RPRO: 0             RPVT: PTR 0x1030c70 RSET: PTR 0x7fb146f9e860
RVAL: 0             SCAN: Passive       SDIS: CONSTANT      SDLY: -1
SEVR: INVALID       SIML: CONSTANT      SIMM: NO            SIMPVT: PTR (nil)
SIMS: NO_ALARM      SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>
STAT: UDF           TIME: 2021-05-27 15:51:06.243005887     TPRO: 0
TSE : 0             TSEL: CONSTANT      UDF : 0             UDFS: INVALID
VAL : 0             WDPT: PTR (nil)     ZNAM: Closed        ZSV : NO_ALARM
/Torsten
On 5/27/21 2:21 PM, Ralph Lange via Tech-talk wrote:
Hi Torsten,
On Thu, 27 May 2021 at 12:53, Torsten Bögershausen via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Asyn-Experts,
    I am chasing an interesting problem.
    For a motor, we have a clutch that can be opened under very
    special conditions, say service mode.
    We define it like this:
    The alarm seem to go away, if the record is processed one more time.
    (by disconnecting the IOC from the controller and re-establishing the
    connection).
    Is this a know phenomena ?
    Anything that can be done ?
How does the setup behave when using Channel Access?
(To see if it is a problem on the ASYN side or the QSRV side of the database.)
Cheers,
~Ralph
Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Next: Re: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
