Subject: Re: asyn bo record staying in INVALID DRIVER UDF
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>, "Rivers, Mark" <[email protected]>
Date: Fri, 28 May 2021 12:54:13 +0200
Hej again,
To start with, I cleanup up the white-spaces that had smuggled
into asyn here:
https://github.com/epics-modules/asyn/pull/134
For the "INVALID DRIVER UDF" I added a PR here,
but that is just for discussion:
https://github.com/epics-modules/asyn/pull/133
BR
/Torsten
On 5/28/21 11:29 AM, Torsten Bögershausen via Tech-talk wrote:
Hej Ralph,
I don't know if I understand the question 100%.
So let me try to explain, what is happening:
In st.cmd, we start a poller thread, talking to the hardware
(=motion controller unit, MCU in ESS speach)
(And the poller is a model 3 motordriver)
When the poller reads the value from the MCU, it calls
              setIntegerParam(axisNo, function,  newValue);
              callBacksNeeded = 1;
and later
    if (callBacksNeeded) {
      callParamCallbacks();
When the IOC is not yet started, the callbacks are blocked somewhere.
But the setIntegerParam() succeeds and the new value is in the
asyn parameter libray.
The bo record does this, once the record need to be initialized:
static long initBo(boRecord *pr)
    devPvt *pPvt;
    int status;
    epicsInt32 value;
    status = initCommon((dbCommon *)pr,&pr->out,
       processCallbackOutput,interruptCallbackOutput, interruptCallbackEnumBo,
        2, (char*)&pr->znam, NULL, &pr->zsv);
    if (status != INIT_OK) return status;
    pPvt = pr->dpvt;
    /* Read the current value from the device */
    status = pasynInt32SyncIO->read(pPvt->pasynUserSync,
                      &value, pPvt->pasynUser->timeout);
    if (status == asynSuccess) {
        pr->rval = value;
        return INIT_OK;
    return INIT_DO_NOT_CONVERT;
So when the record can read a value from the paramlib,
pasynInt32SyncIO() return asynSuccess, the value
is put into the record and everything is fine.
But, there is a race:
When the iocInit() is faster than the poller, the record
is initialized in initBo(), but kept in
"INVALID DRIVER UDF" alarm state.
Later (could be milliseconds, seconds, whatever)
when the poller can talk to the MCU, it will write the value
into the paramlibrary (as before).
(The dev support will resset UDF to 0)
A record processing is triggered and executed.
The new value is in the record, but the alarm status stays,
until the record is processed another time:
static long processBo(boRecord *pr)
    devPvt *pPvt = (devPvt *)pr->dpvt;
    int status;
    epicsMutexLock(pPvt->devPvtLock);
    if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
        /* We got a callback from the driver */
        if (pPvt->result.status == asynSuccess) {
            pr->rval = pPvt->result.value;
            pr->val = (pr->rval) ? 1 : 0;
            pr->udf = 0;
If I change the code like this:
    int status;
      fprintf(stdout, "%s/%s:%d %s pPvt->result.status=%d\n",
           __FILE__, __FUNCTION__, __LINE__,
           pr->name, pPvt->result.status);
            if (pr->udf) {
                pr->udf = 0;
                pr->nsta = 0;
                pr->nsev = 0;
Everything is fine.
Does this explain anything ?
Thanks to everybody
/Torsten
On 5/28/21 11:02 AM, Ralph Lange via Tech-talk wrote:
Might that be related to the initial readback being an asynchronous process(ing)?
The whole idea of doing an initial readback as part of record initialization is based on the assumption that the readback is immediate, i.e. synchronous. If it is asynchronous and the device answer is only accepted after the equivalent of interruptAccept being true, the timing and order of things may be pretty different. In those cases, initial readback has to be done as part of PINI processing, as that runs late enough and works with asynchronous device access. In case that asyn:READBACK is set, the read request can be done as part of the record initialization if the device answer is delayed long enough (or queued) to be processed after interruptAccept. Dropping the device answer would leave the record with UDF cleared (from the silent initial readback) but without processing (as the device answer was lost), which resembles what Torsten is seeing, doesn't it?
Cheers,
~Ralph
asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
RE: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Ralph Lange via Tech-talk
Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Prev: Re: asyn bo record staying in INVALID DRIVER UDF Torsten Bögershausen via Tech-talk
Next: Re: Epics MODbus driver, can this be run as a MODbus Slave? Mark Rivers via Tech-talk
Next: RE: asyn bo record staying in INVALID DRIVER UDF Mark Rivers via Tech-talk
