Subject: Re: caRepeater w/ systemd?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 30 May 2021 09:15:23 -0500
On 5/24/21 9:33 AM, Johnson, Andrew N. wrote:
> On May 23, 2021, at 9:57 AM, Michael Davidsaver via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>> The caRepeater.service currently included in Base is in need of improvement.
>> eg. to not run as root.
> That’s about the one thing that it /doesn’t/ do, line 22 <https://github.com/epics-base/epics-base/blob/b777233efb06fa4e988c4f0738b0270dd3d095a3/modules/ca/src/client/caRepeater.service@#L22> configures it to run as daemon:
Daemons can (and imo should) be constrained to prevent unnecessary operations.
eg. disallow filesystem writes with "ProtectSystem=strict" when run as root.
Or "ProtectHome=true" "PrivateTmp=true" to prevent snooping.
This is an expression of the idea of defense in depth, and is generally seen
as good practice these days.  Especially for a network service.
>> *tux% *ps -ef | grep caRepeater
>> daemon    2255     1  0 Apr21 ?        00:02:51 /usr/bin/*caRepeater*
>> *tux% *systemctl status caRepeater.service
>> *●*caRepeater.service - EPICS CA Repeater
>>    Loaded: loaded (/usr/lib/systemd/system/caRepeater.service; enabled; vendor preset: disabled)
>>    Active: *active (running)*since Wed 2021-04-21 09:03:16 CDT; 1 months 2 days ago
>>  Main PID: 2255 (caRepeater)
>>     Tasks: 1
>>    CGroup: /system.slice/caRepeater.service
>>            └─2255 /usr/bin/caRepeater
> I’m not saying it couldn’t be significantly improved <https://www.redhat.com/sysadmin/systemd-secure-services> though:
>> *$ *systemd-analyze security caRepeater.service
>>   NAME                                                        DESCRIPTION                                                             EXPOSURE
>> *✗*PrivateNetwork=                                             Service has access to the host's network                                     0.5
>> *✓*User=/DynamicUser=                                          Service runs under a static non-root user identity
>> *✗*CapabilityBoundingSet=~CAP_SET(UID|GID|PCAP)                Service may change UID/GID identities/capabilities                           0.3
>> *✗*CapabilityBoundingSet=~CAP_SYS_ADMIN                        Service has administrator privileges                                         0.3
>> *✗*CapabilityBoundingSet=~CAP_SYS_PTRACE                       Service has ptrace() debugging abilities                                     0.3
>> *✗*RestrictAddressFamilies=~AF_(INET|INET6)                    Service may allocate Internet sockets                                        0.3
>> *✗*RestrictNamespaces=~CLONE_NEWUSER                           Service may create user namespaces                                           0.3
>> *✗*RestrictAddressFamilies=~…                                  Service may allocate exotic sockets                                          0.3
>> *✗*CapabilityBoundingSet=~CAP_(CHOWN|FSETID|SETFCAP)           Service may change file ownership/access mode/capabilities unrestricted      0.2
>> *✗*CapabilityBoundingSet=~CAP_(DAC_*|FOWNER|IPC_OWNER)         Service may override UNIX file/IPC permission checks                         0.2
>> *✗*CapabilityBoundingSet=~CAP_NET_ADMIN                        Service has network configuration privileges                                 0.2
>> *✗*CapabilityBoundingSet=~CAP_RAWIO                            Service has raw I/O access                                                   0.2
>> *✗*CapabilityBoundingSet=~CAP_SYS_MODULE                       Service may load kernel modules                                              0.2
>> *✗*CapabilityBoundingSet=~CAP_SYS_TIME                         Service processes may change the system clock                                0.2
>> *✗*DeviceAllow=                                                Service has no device ACL                                                    0.2
>> *✗*IPAddressDeny=                                              Service does not define an IP address whitelist                              0.2
>> *✓*KeyringMode=                                                Service doesn't share key material with other services
>> *✗*NoNewPrivileges=                                            Service processes may acquire new privileges                                 0.2
>> *✓*NotifyAccess=                                               Service child processes cannot alter service state
>> *✗*PrivateDevices=                                             Service potentially has access to hardware devices                           0.2
>> *✗*PrivateMounts=                                              Service may install system mounts                                            0.2
>> *✗*PrivateTmp=                                                 Service has access to other software's temporary files                       0.2
>> *✗*PrivateUsers=                                               Service has access to other users                                            0.2
>> *✗*ProtectControlGroups=                                       Service may modify to the control group file system                          0.2
>> *✗*ProtectHome=                                                Service has full access to home directories                                  0.2
>> *✗*ProtectKernelModules=                                       Service may load or read kernel modules                                      0.2
>> *✗*ProtectKernelTunables=                                      Service may alter kernel tunables                                            0.2
>> *✗*ProtectSystem=                                              Service has full access the OS file hierarchy                                0.2
>> *✗*RestrictAddressFamilies=~AF_PACKET                          Service may allocate packet sockets                                          0.2
>> *✗*RestrictSUIDSGID=                                           Service may create SUID/SGID files                                           0.2
>> *✗*SystemCallArchitectures=                                    Service may execute system calls with all ABIs                               0.2
>> *✗*SystemCallFilter=~@clock                                    Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@debug                                    Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@module                                   Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@mount                                    Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@raw-io                                   Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@reboot                                   Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@swap                                     Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@privileged                               Service does not filter system calls                                         0.2
>> *✗*SystemCallFilter=~@resources                                Service does not filter system calls                                         0.2
>> *✓*AmbientCapabilities=                                        Service process does not receive ambient capabilities
>> *✗*CapabilityBoundingSet=~CAP_AUDIT_*                          Service has audit subsystem access                                           0.1
>> *✗*CapabilityBoundingSet=~CAP_KILL                             Service may send UNIX signals to arbitrary processes                         0.1
>> *✗*CapabilityBoundingSet=~CAP_MKNOD                            Service may create device nodes                                              0.1
>> *✗*CapabilityBoundingSet=~CAP_NET_(BIND_SERVICE|BROADCAST|RAW) Service has elevated networking privileges                                   0.1
>> *✗*CapabilityBoundingSet=~CAP_SYSLOG                           Service has access to kernel logging                                         0.1
>> *✗*CapabilityBoundingSet=~CAP_SYS_(NICE|RESOURCE)              Service has privileges to change resource use parameters                     0.1
>> *✗*RestrictNamespaces=~CLONE_NEWCGROUP                         Service may create cgroup namespaces                                         0.1
>> *✗*RestrictNamespaces=~CLONE_NEWIPC                            Service may create IPC namespaces                                            0.1
>> *✗*RestrictNamespaces=~CLONE_NEWNET                            Service may create network namespaces                                        0.1
>> *✗*RestrictNamespaces=~CLONE_NEWNS                             Service may create file system namespaces                                    0.1
>> *✗*RestrictNamespaces=~CLONE_NEWPID                            Service may create process namespaces                                        0.1
>> *✗*RestrictRealtime=                                           Service may acquire realtime scheduling                                      0.1
>> *✗*SystemCallFilter=~@cpu-emulation                            Service does not filter system calls                                         0.1
>> *✗*SystemCallFilter=~@obsolete                                 Service does not filter system calls                                         0.1
>> *✗*RestrictAddressFamilies=~AF_NETLINK                         Service may allocate netlink sockets                                         0.1
>> *✗*RootDirectory=/RootImage=                                   Service runs within the host's root directory                                0.1
>> *✓*SupplementaryGroups=                                        Service has no supplementary groups
>> *✗*CapabilityBoundingSet=~CAP_MAC_*                            Service may adjust SMACK MAC                                                 0.1
>> *✗*CapabilityBoundingSet=~CAP_SYS_BOOT                         Service may issue reboot()                                                   0.1
>> *✓*Delegate=                                                   Service does not maintain its own delegated control group subtree
>> *✗*LockPersonality=                                            Service may change ABI personality                                           0.1
>> *✗*MemoryDenyWriteExecute=                                     Service may create writable executable memory mappings                       0.1
>> *✗*RemoveIPC=                                                  Service user may leave SysV IPC objects around                               0.1
>> *✗*RestrictNamespaces=~CLONE_NEWUTS                            Service may create hostname namespaces                                       0.1
>> *✗*UMask=                                                      Files created by service are world-readable by default                       0.1
>> *✗*CapabilityBoundingSet=~CAP_LINUX_IMMUTABLE                  Service may mark files immutable                                             0.1
>> *✗*CapabilityBoundingSet=~CAP_IPC_LOCK                         Service may lock memory into RAM                                             0.1
>> *✗*CapabilityBoundingSet=~CAP_SYS_CHROOT                       Service may issue chroot()                                                   0.1
>> *✗*CapabilityBoundingSet=~CAP_BLOCK_SUSPEND                    Service may establish wake locks                                             0.1
>> *✗*CapabilityBoundingSet=~CAP_LEASE                            Service may create file leases                                               0.1
>> *✗*CapabilityBoundingSet=~CAP_SYS_PACCT                        Service may use acct()                                                       0.1
>> *✗*CapabilityBoundingSet=~CAP_SYS_TTY_CONFIG                   Service may issue vhangup()                                                  0.1
>> *✗*CapabilityBoundingSet=~CAP_WAKE_ALARM                       Service may program timers that wake up the system                           0.1
>> *✗*RestrictAddressFamilies=~AF_UNIX                            Service may allocate local sockets                                           0.1
>> → *Overall exposure level for caRepeater.service*: *9.1 UNSAFE*😨
> - Andrew
> Complexity comes for free, simplicity you have to work for.
Re: caRepeater w/ systemd? Ernesto Paiser via Tech-talk
caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
Prev: Re: using autosave, iocInit hangs Michael Davidsaver via Tech-talk
Next: RE: Display Only Lock and/or pw protection for Phoebus Stainer Tom via Tech-talk
Prev: Re: caRepeater w/ systemd? Johnson, Andrew N. via Tech-talk
Next: Re: caRepeater w/ systemd? Ernesto Paiser via Tech-talk
