Subject: Re: caRepeater w/ systemd?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 24 May 2021 16:33:24 +0000
On May 23, 2021, at 9:57 AM, Michael Davidsaver via Tech-talk <[email protected]> wrote:
The caRepeater.service currently included in Base is in need of improvement.
eg. to not run as root.
That’s about the one thing that it doesn’t do, line 22 configures it to run as daemon:
tux% ps -ef | grep caRepeater
daemon    2255     1  0 Apr21 ?        00:02:51 /usr/bin/caRepeater
tux% systemctl status caRepeater.service
caRepeater.service - EPICS CA Repeater
   Loaded: loaded (/usr/lib/systemd/system/caRepeater.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2021-04-21 09:03:16 CDT; 1 months 2 days ago
 Main PID: 2255 (caRepeater)
    Tasks: 1
   CGroup: /system.slice/caRepeater.service
           └─2255 /usr/bin/caRepeater
I’m not saying it couldn’t be significantly improved though:
systemd-analyze security caRepeater.service
  NAME                                                        DESCRIPTION                                                             EXPOSURE
PrivateNetwork=                                             Service has access to the host's network                                     0.5
User=/DynamicUser=                                          Service runs under a static non-root user identity
CapabilityBoundingSet=~CAP_SET(UID|GID|PCAP)                Service may change UID/GID identities/capabilities                           0.3
CapabilityBoundingSet=~CAP_SYS_ADMIN                        Service has administrator privileges                                         0.3
CapabilityBoundingSet=~CAP_SYS_PTRACE                       Service has ptrace() debugging abilities                                     0.3
RestrictAddressFamilies=~AF_(INET|INET6)                    Service may allocate Internet sockets                                        0.3
RestrictNamespaces=~CLONE_NEWUSER                           Service may create user namespaces                                           0.3
RestrictAddressFamilies=~…                                  Service may allocate exotic sockets                                          0.3
CapabilityBoundingSet=~CAP_(CHOWN|FSETID|SETFCAP)           Service may change file ownership/access mode/capabilities unrestricted      0.2
CapabilityBoundingSet=~CAP_(DAC_*|FOWNER|IPC_OWNER)         Service may override UNIX file/IPC permission checks                         0.2
CapabilityBoundingSet=~CAP_NET_ADMIN                        Service has network configuration privileges                                 0.2
CapabilityBoundingSet=~CAP_RAWIO                            Service has raw I/O access                                                   0.2
CapabilityBoundingSet=~CAP_SYS_MODULE                       Service may load kernel modules                                              0.2
CapabilityBoundingSet=~CAP_SYS_TIME                         Service processes may change the system clock                                0.2
DeviceAllow=                                                Service has no device ACL                                                    0.2
IPAddressDeny=                                              Service does not define an IP address whitelist                              0.2
KeyringMode=                                                Service doesn't share key material with other services
NoNewPrivileges=                                            Service processes may acquire new privileges                                 0.2
NotifyAccess=                                               Service child processes cannot alter service state
PrivateDevices=                                             Service potentially has access to hardware devices                           0.2
PrivateMounts=                                              Service may install system mounts                                            0.2
PrivateTmp=                                                 Service has access to other software's temporary files                       0.2
PrivateUsers=                                               Service has access to other users                                            0.2
ProtectControlGroups=                                       Service may modify to the control group file system                          0.2
ProtectHome=                                                Service has full access to home directories                                  0.2
ProtectKernelModules=                                       Service may load or read kernel modules                                      0.2
ProtectKernelTunables=                                      Service may alter kernel tunables                                            0.2
ProtectSystem=                                              Service has full access the OS file hierarchy                                0.2
RestrictAddressFamilies=~AF_PACKET                          Service may allocate packet sockets                                          0.2
RestrictSUIDSGID=                                           Service may create SUID/SGID files                                           0.2
SystemCallArchitectures=                                    Service may execute system calls with all ABIs                               0.2
SystemCallFilter=~@clock                                    Service does not filter system calls                                         0.2
SystemCallFilter=~@debug                                    Service does not filter system calls                                         0.2
SystemCallFilter=~@module                                   Service does not filter system calls                                         0.2
SystemCallFilter=~@mount                                    Service does not filter system calls                                         0.2
SystemCallFilter=~@raw-io                                   Service does not filter system calls                                         0.2
SystemCallFilter=~@reboot                                   Service does not filter system calls                                         0.2
SystemCallFilter=~@swap                                     Service does not filter system calls                                         0.2
SystemCallFilter=~@privileged                               Service does not filter system calls                                         0.2
SystemCallFilter=~@resources                                Service does not filter system calls                                         0.2
AmbientCapabilities=                                        Service process does not receive ambient capabilities
CapabilityBoundingSet=~CAP_AUDIT_*                          Service has audit subsystem access                                           0.1
CapabilityBoundingSet=~CAP_KILL                             Service may send UNIX signals to arbitrary processes                         0.1
CapabilityBoundingSet=~CAP_MKNOD                            Service may create device nodes                                              0.1
CapabilityBoundingSet=~CAP_NET_(BIND_SERVICE|BROADCAST|RAW) Service has elevated networking privileges                                   0.1
CapabilityBoundingSet=~CAP_SYSLOG                           Service has access to kernel logging                                         0.1
CapabilityBoundingSet=~CAP_SYS_(NICE|RESOURCE)              Service has privileges to change resource use parameters                     0.1
RestrictNamespaces=~CLONE_NEWCGROUP                         Service may create cgroup namespaces                                         0.1
RestrictNamespaces=~CLONE_NEWIPC                            Service may create IPC namespaces                                            0.1
RestrictNamespaces=~CLONE_NEWNET                            Service may create network namespaces                                        0.1
RestrictNamespaces=~CLONE_NEWNS                             Service may create file system namespaces                                    0.1
RestrictNamespaces=~CLONE_NEWPID                            Service may create process namespaces                                        0.1
RestrictRealtime=                                           Service may acquire realtime scheduling                                      0.1
SystemCallFilter=~@cpu-emulation                            Service does not filter system calls                                         0.1
SystemCallFilter=~@obsolete                                 Service does not filter system calls                                         0.1
RestrictAddressFamilies=~AF_NETLINK                         Service may allocate netlink sockets                                         0.1
RootDirectory=/RootImage=                                   Service runs within the host's root directory                                0.1
SupplementaryGroups=                                        Service has no supplementary groups
CapabilityBoundingSet=~CAP_MAC_*                            Service may adjust SMACK MAC                                                 0.1
CapabilityBoundingSet=~CAP_SYS_BOOT                         Service may issue reboot()                                                   0.1
Delegate=                                                   Service does not maintain its own delegated control group subtree
LockPersonality=                                            Service may change ABI personality                                           0.1
MemoryDenyWriteExecute=                                     Service may create writable executable memory mappings                       0.1
RemoveIPC=                                                  Service user may leave SysV IPC objects around                               0.1
RestrictNamespaces=~CLONE_NEWUTS                            Service may create hostname namespaces                                       0.1
UMask=                                                      Files created by service are world-readable by default                       0.1
CapabilityBoundingSet=~CAP_LINUX_IMMUTABLE                  Service may mark files immutable                                             0.1
CapabilityBoundingSet=~CAP_IPC_LOCK                         Service may lock memory into RAM                                             0.1
CapabilityBoundingSet=~CAP_SYS_CHROOT                       Service may issue chroot()                                                   0.1
CapabilityBoundingSet=~CAP_BLOCK_SUSPEND                    Service may establish wake locks                                             0.1
CapabilityBoundingSet=~CAP_LEASE                            Service may create file leases                                               0.1
CapabilityBoundingSet=~CAP_SYS_PACCT                        Service may use acct()                                                       0.1
CapabilityBoundingSet=~CAP_SYS_TTY_CONFIG                   Service may issue vhangup()                                                  0.1
CapabilityBoundingSet=~CAP_WAKE_ALARM                       Service may program timers that wake up the system                           0.1
RestrictAddressFamilies=~AF_UNIX                            Service may allocate local sockets                                           0.1
Overall exposure level for caRepeater.service: 9.1 UNSAFE 😨
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Prev: using autosave, iocInit hangs junkes via Tech-talk
Next: EPICS support for Julabo chiller Neuman, Urszula (DLSLtd, RAL, LSCI) via Tech-talk
Prev: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
Next: Re: caRepeater w/ systemd? Michael Davidsaver via Tech-talk
