Subject: Re: [epics-modules/asyn] records with asyn:READBACK are not always setting STAT and SEVR correctly when UDF=0 (#136)
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: <[email protected]>
Cc: Subscribed <[email protected]>, epics-modules/asyn <[email protected]>
Date: Mon, 31 May 2021 10:00:44 +0200
Hej Mark,
thanks for digging.
The problem can probably fixed in asyn or in boRecord.c,which is part of EPICS base.
I took the time to do some more printf-ing.
Setting/reseting the different alarm states/severies seems to be a splitter resonsiblity
between the record code (in EPICS Base) an device support in asyn.
My conclusionfor the moment is that the device support is the "first one to know” that there
has been a UDF=1 -> UDF=0 transition, caused by a callback.
Because now we need to build up the new alarm state/severity from scratch.
My suggestion is a change/improvement  in asyn:
<https://github.com/EuropeanSpallationSource/asyn/commit/459d2697b6a6747d051adcec7b6ee826fff4e2ea>
But we may argue that EPICS Base is a better place to fix it.
BR
/Torsten
> On 29 May 2021, at 17:11, Mark Rivers <[email protected]> wrote:
> I modified devAsynInt32.c::processBo to print some debugging as follows:
> diff --git a/asyn/devEpics/devAsynInt32.c b/asyn/devEpics/devAsynInt32.c
> index 4dfc50c..8d1ab1e 100644
> --- a/asyn/devEpics/devAsynInt32.c
> +++ b/asyn/devEpics/devAsynInt32.c
> @@ -1213,37 +1213,40 @@ static long processBo(boRecord *pr)
>      devPvt *pPvt = (devPvt *)pr->dpvt;
>      int status;
>      epicsMutexLock(pPvt->devPvtLock);
>      if(pPvt->newOutputCallbackValue && getCallbackValue(pPvt)) {
>          /* We got a callback from the driver */
>          if (pPvt->result.status == asynSuccess) {
>              pr->rval = pPvt->result.value;
>              pr->val = (pr->rval) ? 1 : 0;
>              pr->udf = 0;
> +            asynPrint(pPvt->pasynUser, ASYN_TRACE_WARNING, "processBo record=%s, udf=0\n", pr->name);
>      } else if(pr->pact == 0) {
>          pPvt->result.value = pr->rval;
>          if(pPvt->canBlock) {
>              pr->pact = 1;
>              pPvt->asyncProcessingActive = 1;
>          epicsMutexUnlock(pPvt->devPvtLock);
>          status = pasynManager->queueRequest(pPvt->pasynUser, 0, 0);
>          if((status==asynSuccess) && pPvt->canBlock) return 0;
>          if(pPvt->canBlock) pr->pact = 0;
>          reportQueueRequestStatus(pPvt, status);
>      pasynEpicsUtils->asynStatusToEpicsAlarm(pPvt->result.status,
>                                              WRITE_ALARM, &pPvt->result.alarmStatus,
>                                              INVALID_ALARM, &pPvt->result.alarmSeverity);
> +    asynPrint(pPvt->pasynUser, ASYN_TRACE_WARNING, "processBo record=%s, calling recGblSetSevr status=%d, severity=%d\n",
> +              pr->name, pPvt->result.alarmStatus, pPvt->result.alarmSeverity);
>      (void)recGblSetSevr(pr, pPvt->result.alarmStatus, pPvt->result.alarmSeverity);
>      if (pPvt->numDeferredOutputCallbacks > 0) {
>          callbackRequest(&pPvt->outputCallback);
>          pPvt->numDeferredOutputCallbacks--;
>      pPvt->newOutputCallbackValue = 0;
>      pPvt->asyncProcessingActive = 0;
>      if(pPvt->result.status == asynSuccess) {
>          return 0;
> So it prints the a message when it sets udf=0 and it prints a message just before it calls recGblSetSevr with the values it is setting for status and severity.
> This is now the complete output after iocInit:
> iocRun: All initialization complete
> date
> 2021/05/29 10:03:51.073336
> dbpr testAPD:scope1:Clutch 2
> ACKS: NO_ALARM      ACKT: YES           ASG :               BKPT: 00
> COSV: NO_ALARM      DESC:               DISA: 0             DISP: 0
> DISS: NO_ALARM      DISV: 1             DOL : CONSTANT      DTYP: asynInt32
> EVNT:               FLNK: CONSTANT      HIGH: 0
> IVOA: Continue normally                 IVOV: 0             LCNT: 0
> MASK: 0             NAME: testAPD:scope1:Clutch             NSEV: NO_ALARM
> NSTA: NO_ALARM      OMSL: supervisory   ONAM: On            OSV : NO_ALARM
> OUT : INST_IO @asyn(testAPD,0,1)CLUTCH  PACT: 0             PHAS: 0
> PINI: NO            PRIO: LOW           PUTF: 0             RBV : 0
> RPRO: 0             RVAL: 0             SCAN: Passive       SDIS: CONSTANT
> SDLY: -1            SEVR: INVALID       SIML: CONSTANT      SIMM: NO
> SIMS: NO_ALARM      SIOL: CONSTANT      SSCN: <nil>         STAT: UDF
> TIME: <undefined>   TPRO: 1             TSE : 0             TSEL: CONSTANT
> UDF : 1             UDFS: INVALID       VAL : 0             ZNAM: Off
> ZSV : NO_ALARM
> epicsThreadSleep(3)
> cbLow: dbProcess of 'testAPD:scope1:Clutch'
> 2021/05/29 10:03:52.566 processBo record=testAPD:scope1:Clutch, udf=0
> 2021/05/29 10:03:52.566 processBo record=testAPD:scope1:Clutch, calling recGblSetSevr status=0, severity=0
> date
> 2021/05/29 10:03:54.073656
> RPRO: 0             RVAL: 1             SCAN: Passive       SDIS: CONSTANT
> TIME: 2021-05-29 10:03:52.565900993     TPRO: 1             TSE : 0
> TSEL: CONSTANT      UDF : 0             UDFS: INVALID       VAL : 1
> ZNAM: Off           ZSV : NO_ALARM
> epicsThreadSleep(3)
> 2021/05/29 10:03:54.566 processBo record=testAPD:scope1:Clutch, udf=0
> 2021/05/29 10:03:54.566 processBo record=testAPD:scope1:Clutch, calling recGblSetSevr status=0, severity=0
> date
> 2021/05/29 10:03:57.073942
> SDLY: -1            SEVR: NO_ALARM      SIML: CONSTANT      SIMM: NO
> SIMS: NO_ALARM      SIOL: CONSTANT      SSCN: <nil>         STAT: NO_ALARM
> TIME: 2021-05-29 10:03:54.565963934     TPRO: 1             TSE : 0
> TSEL: CONSTANT      UDF : 0             UDFS: INVALID       VAL : 0
> Note that the first time the record processes it has indeed set udf=0 and called recGblSetSevr with status=0, severity=0. Yet for some reason the record STAT and SEVR fields are UDF and INVALID.
> I am having a hard time seeing that I am doing something wrong in asyn.
> You are receiving this because you are subscribed to this thread.
> Reply to this email directly, view it on GitHub, or unsubscribe.
Prev: RE: Display Only Lock and/or pw protection for Phoebus Stainer Tom via Tech-talk
Next: React Automation Studio V3.0.0 wduckitt via Tech-talk
Prev: Re: Epics MODbus driver, can this be run as a MODbus Slave? Mark Rivers via Tech-talk
