Well, From:
Stainer Tom <[email protected]>
What I meant with CA <-> PVA translators is if some device is providing data over CA is there a way to make a proxy or gateway to wrap this and convert it to a corresponding PVA signal? As you mentioned below, avoiding vendor specific EPICS integration is always desired but sometimes unavoidable and I was thinking in these cases what can you do if you want only PVA….. On Tue, 8 Jun 2021 at 17:54, Timo Korhonen via Tech-talk <[email protected]> wrote:
For a modular approach... the existing gateway is called IOC. Create records pointing to the "CA speaking device" and use QSRV to provide them as pvAccess. That has the advantages of being fully compatible with all your other IOCs, moving its EPICS version with all your other IOCs, not using any specific implementations of CA client or PVA server, allowing to put additional logic into the glue layer
(add health monitoring, add logging, combine things, change record names, etc.) without introducing new concepts, languages or implementations and cleanly separating that gateway functionality between different use cases. At ITER, our practice is to put an IOC in front of any "CA speaking device", just for the sake of conformity and flexibility. With maybe the exception of the device running an original IOC that we have full control over - OS, EPICS version, database... which I don't expect to happen. High bandwidth low latency applications - think detectors - may become the other exception. Cheers, ~Ralph
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
