> I see that if I use BINP I can adjust the character limit if I restart the IOC, but ideally I would like to avoid this.
You only need to restart the IOC once and set IMAX=1024 or some other size that will always be large enough when you load asynRecord.db. You then set the input format (IFMT) to "Hybrid" which uses the large BINP buffer but still does EOS processing.
From: Tech-talk <[email protected]> on behalf of Sobhani, Bayan via Tech-talk <[email protected]>
Sent: Thursday, June 10, 2021 3:12 AM
To: [email protected]
Subject: Reading multiple lines from an asyn record
I have an asyn record to a device:
https://epics.anl.gov/modules/soft/asyn/R3-2/asynRecord.html
I would like to download files from this device to my computer, that consist of carriage return separated lines. The problem is the 40 character limit. I see that if I use BINP I can adjust the character limit if I restart the IOC, but ideally I would like to avoid this.
Is there a way to get the record to read one line at a time? If I could somehow get every line of the file read with a camonitor of the PV this would be good enough for me.
Alex
- Reading multiple lines from an asyn record Sobhani, Bayan via Tech-talk
Re: Writing to Waveform from CALC Mark Rivers via Tech-talk
Make compilation having weird behavior Marco A. Barra Montevechi Filho via Tech-talk
<2021>
2025
2026
Re: Reading multiple lines from an asyn record Ralph Lange via Tech-talk
Writing to Waveform from CALC Florian Feldbauer via Tech-talk
<2021>
2025
2026
