Subject: RE: Instructions on using manage-procs procServ and Conserver
From: "Smith, William via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Mon, 14 Jun 2021 07:42:34 +0000
Hi Michael,
I will open a ticket on github. In case anybody ever searches for something similar on techtalk I will also post what these two files look like below. Under ~/.config/procServ.d/ two files are created each time. One file called procserv-sampleIOC1.service is created, another called sampleIOC1.conf. The conf file looks correct:
[sampleIOC1]
command = /home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC/st.cmd -c
chdir = /home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC
port = 7010
However, the service file looks incorrect:
[Unit]
Description=procServ for sampleIOC1
After=network.target remote-fs.target
ConditionPathIsDirectory=/home/emil/Apps/epics/R7.0.4.1/work/ioc/TEST/sampleIOC/iocBoot/iocsampleIOC
[Service]
Type=simple
ExecStart=None --user sampleIOC1
RuntimeDirectory=procserv-sampleIOC1
StandardOutput=syslog
StandardError=inherit
SyslogIdentifier=procserv-sampleIOC1
[Install]
WantedBy=multi-user.target
Will
-----Original Message-----
Sent: Friday, June 11, 2021 8:26 PM
To: Smith, William <[email protected]>
Cc: [email protected]
Subject: Re: Instructions on using manage-procs procServ and Conserver
On 6/11/21 10:38 AM, Smith, William via Tech-talk wrote:
> cat /home/emil/.config/procServ.d/procserv-sampleIOC1.service
> [Service]
> Any idea what I am doing wrong?
The 'ExecStart' line is clearly not correct, so it looks like you've found a bug.
Would you like to open a ticket?  https://github.com/ralphlange/procServ
Please check to see if the config file under ~/.config/procServ.d/ has 'None' or 'st.cmd'.
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Instructions on using manage-procs procServ and Conserver Smith, William via Tech-talk
Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Prev: RE: Instructions on using manage-procs procServ and Conserver Smith, William via Tech-talk
Next: Re: Best way to properly "synchronize" records between two IOCs Mark Rivers via Tech-talk
Prev: Re: Instructions on using manage-procs procServ and Conserver Michael Davidsaver via Tech-talk
Next: Re: Instructions on using manage-procs procServ and Conserver Hu, Yong via Tech-talk
