Subject: EpicsSharp not reading PVs from EPICS gateway
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thu, 17 Jun 2021 13:38:03 +0000
Hi
I am facing an issue reading a PV from another VLAN using EPICS gateway. Assume we have two VLANs 1 and 2, the EPICS gateway is installed on a virtual server having a separate NIC for each VLAN and each NIC has an IP from the corresponding VLAN. A PC on VLAN 1 can caget a PV from VLAN 2, but an application using EpicsSharp on the same PC can’t read the same PV. I tried the “SearchAddress” property, setting EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST=NO but nothing works. All of that while caget is working. What am I missing here?
Thanks in advance
Abdalla.
Prev: database could big data, compute and analyse 网易邮件中心 via Tech-talk
Next: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Next: Network Hardware Recommendation Josh Fiddler via Tech-talk
