Subject: Re: Get timestamp from another IOC
From: Adrian Martinez via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 18 Jun 2021 08:05:39 +0200
Hello,
Thanks for all!! Finally, I've solved the problem using any other PV which was being updated.
Like you said, if the VAL field doesn't update, timestamp value will not update.
Regards, Adrián.
El mié, 16 jun 2021 a las 17:39, Johnson, Andrew N. (<[email protected]>) escribió:
Hi Adrian,
On Jun 16, 2021, at 9:49 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
I've used 'dbr' command on IOC1 and this is the out for Timestamp_from_IOC1:
ioc > dbpr MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 10
ACKS: NO_ALARM      ACKT: YES           APST: On Change     ASG:
ASP: (nil)          BKPT: 00            DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x153cf30
DSET: 0x7f5fc4122160                    DTYP: Obj Prop string
EVNT:               FLNK:DB_LINK MBT-RBN:TMG-EVR-01:TimeErr-I
INP:INST_IO @OBJ=EVR-MTCA, PROP=NextSecond                  LCNT: 0
LSET: 0x1410530
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 85 50 01 00 00 00 00           MPST: On Change
Timestamp_from_IOC1   NSEV: NO_ALARM      NSTA: NO_ALARM
OVAL: Sun, 07 Feb 2106 06:28:16         PACT: 0             PHAS: 0
PINI: NO            PPN: (nil)          PPNR: (nil)         PRIO: LOW
PROC: 0             PUTF: 0             RDES: 0x1242bc0     RPRO: 0
RSET: 0x7f5fc3ca6560                    SCAN: 1 second      SDIS:CONSTANT
SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM
SIOL:CONSTANT       SPVT: 0x1558ce0     STAT: NO_ALARM      SVAL:
TIME: 2021-06-16 14:47:16.997443401     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 1              UDFS: INVALID
The SCAN field is 1s, VAL field never changes but the TIME field of the PV does.
That explains why your source record isn’t getting a new timestamp then; the TSEL link actually sets up a CA monitor on the VAL field, so if that monitor never updates it will never get a new timestamp value.
If you set the MPST field of the above record to “Always” it will cause every process to generate a monitor update, which will update your other records.
- Andrew
Complexity comes for free, simplicity you have to work for.
Adrián Martínez
Embedded Software Engineer
Seven Solutions
Mail: [email protected]
www.sevensols.com
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Prev: EpicsSharp not reading PVs from EPICS gateway Abdalla Ahmad via Tech-talk
Next: Network Hardware Recommendation Josh Fiddler via Tech-talk
Prev: Re: Get timestamp from another IOC Timo Korhonen via Tech-talk
Next: Re: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
