FWIW, I found the APST and MPST fields in waveform, aai, aao, lsi and lso records as well (EPICS base 7.0.5).
Timo
Wow, good to know the fields of APST and MPST which seem specific to stringin / stringout.
https://epics.anl.gov/base/R7-0/5-docs/stringinRecord.html
These two fields are also available in base-3.14.12 (which is still being used at NSLS-2). But they are not documented in the old wiki “This Wiki is no longer being maintained”:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_String_Input
Hi Adrian,
On Jun 16, 2021, at 9:49 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
I've used 'dbr' command on
IOC1 and this is the out for Timestamp_from_IOC1:
ioc > dbpr MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 10
ACKS: NO_ALARM ACKT: YES APST: On Change ASG:
ASP: (nil) BKPT: 00 DESC: DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: 0x153cf30
DSET: 0x7f5fc4122160 DTYP: Obj Prop string
EVNT: FLNK:DB_LINK MBT-RBN:TMG-EVR-01:TimeErr-I
INP:INST_IO @OBJ=EVR-MTCA, PROP=NextSecond LCNT: 0
LSET: 0x1410530
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 85 50 01 00 00 00 00 MPST: On Change
NAME: MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 NSEV: NO_ALARM NSTA: NO_ALARM
OVAL: Sun, 07 Feb 2106 06:28:16 PACT: 0 PHAS: 0
PINI: NO PPN: (nil) PPNR: (nil) PRIO: LOW
PROC: 0 PUTF: 0 RDES: 0x1242bc0 RPRO: 0
RSET: 0x7f5fc3ca6560 SCAN: 1 second SDIS:CONSTANT
SEVR: NO_ALARM SIML:CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL:CONSTANT SPVT: 0x1558ce0 STAT: NO_ALARM SVAL:
TIME: 2021-06-16 14:47:16.997443401 TPRO: 0 TSE: 0
TSEL:CONSTANT UDF: 1 UDFS: INVALID
The SCAN field is 1s, VAL field never changes but the TIME field of the PV does.
That explains why your source record isn’t getting a new timestamp then; the TSEL link actually sets up a CA monitor on the VAL field, so if that monitor never updates it will never get a new timestamp value.
If you set the MPST field of the above record to “Always” it will cause every process to generate a monitor update, which will update your other records.
Complexity comes for free, simplicity you have to work for.
