Subject: Re: Get timestamp from another IOC
To: "Johnson, Andrew N." <[email protected]>, Adrian Martinez <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 16 Jun 2021 16:00:59 +0000
Wow, good to know the fields of APST and MPST which seem specific to stringin / stringout.
https://epics.anl.gov/base/R7-0/5-docs/stringinRecord.html
These two fields are also available in base-3.14.12 (which is still being used at NSLS-2). But they are not documented in the old wiki “This Wiki is no longer being maintained”:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_String_Input
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Date: Wednesday, June 16, 2021 at 11:39 AM
To: Adrian Martinez <[email protected]>
Hi Adrian,
On Jun 16, 2021, at 9:49 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
I've used 'dbr' command on IOC1 and this is the out for Timestamp_from_IOC1:
ioc > dbpr MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 10
ACKS: NO_ALARM      ACKT: YES           APST: On Change     ASG:
ASP: (nil)          BKPT: 00            DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x153cf30
DSET: 0x7f5fc4122160                    DTYP: Obj Prop string
EVNT:               FLNK:DB_LINK MBT-RBN:TMG-EVR-01:TimeErr-I
INP:INST_IO @OBJ=EVR-MTCA, PROP=NextSecond                  LCNT: 0
LSET: 0x1410530
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 85 50 01 00 00 00 00           MPST: On Change
NAME: MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1   NSEV: NO_ALARM      NSTA: NO_ALARM
OVAL: Sun, 07 Feb 2106 06:28:16         PACT: 0             PHAS: 0
PINI: NO            PPN: (nil)          PPNR: (nil)         PRIO: LOW
PROC: 0             PUTF: 0             RDES: 0x1242bc0     RPRO: 0
RSET: 0x7f5fc3ca6560                    SCAN: 1 second      SDIS:CONSTANT
SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM
SIOL:CONSTANT       SPVT: 0x1558ce0     STAT: NO_ALARM      SVAL:
TIME: 2021-06-16 14:47:16.997443401     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 1              UDFS: INVALID
The SCAN field is 1s, VAL field never changes but the TIME field of the PV does.
That explains why your source record isn’t getting a new timestamp then; the TSEL link actually sets up a CA monitor on the VAL field, so if that monitor never updates it will never get a new timestamp value.
If you set the MPST field of the above record to “Always” it will cause every process to generate a monitor update, which will update your other records.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Get timestamp from another IOC Timo Korhonen via Tech-talk
Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Prev: Re: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
Next: RE:FLIR camera bit depth configuration with ADSpinnaker BENEDETTI Florian via Tech-talk
Prev: Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Next: Re: Get timestamp from another IOC Timo Korhonen via Tech-talk
