Subject: |
StreamDevice support problem: Cannot find a bus named 'L0' for... |
Hasan SANSAR via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 22 Jun 2021 15:45:22 +0300 |
I am a new member of EPICS platform. I installed EPICS
R3.15.8.1-DEV from LaunchPad that given 'git' command on
epics-contols.org and also StreamDevice and asyn from GitHub,
and so I applied instructions on docs.epics-controls.org and
there is no problem for installation and for example of creation
IOC.
My environment is Debian GNU/Linux 10 Buster server
installation without desktop GUI on Virtual Box. I'm trying to
connect TDK-Lambda Z36-12-LAN Power Supply through ethernet
connection with ethernet cable. There is no problem, because I
can get ping from power supply's IP on Debian Virtualbox.
All in all, I start to follow Eric Norum's tutorial about
device support (Or else, is it deprecated?):
https://epics.anl.gov/modules/soft/asyn/R4-24/HowToDoSerial/HowToDoSerial_StreamDevice.html
And I get error end of third step below. (I added several
informations below of the error message.) I think stream does
not detect asyn, but why?
~/EPICS/IOCs/TDK/iocBoot/iocTDKtest$ ./st.cmd
#!../../bin/linux-x86_64/TDKtest
## You may have to change TDKtest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocTDKtest")
epicsEnvSet("TOP","/home/osiloskop/EPICS/IOCs/TDK")
epicsEnvSet("STREAM","/home/osiloskop/EPICS/support/StreamDevice")
epicsEnvSet "STREAM_PROTOCOL_PATH"
"/home/osiloskop/EPICS/IOCs/TDK/db"
# Allow PV name prefixes and serial port name to be set
from the environment
epicsEnvSet "P" "tdk_lambda"
epicsEnvSet "R" "Test"
epicsEnvSet "TTY" "10.97.4.4:8003"
cd "/home/osiloskop/EPICS/IOCs/TDK"
dbLoadDatabase "dbd/TDKtest.dbd"
TDKtest_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority
noAutoconnect noProcessEos
drvAsynIPPortConfigure("L0","10.97.4.4:8003",0,0,0)
st.cmd line 22: Command drvAsynIPPortConfigure not found.
asynSetTraceIOMask("L0",-1,0x2)
st.cmd line 23: Command asynSetTraceIOMask not found.
asynSetTraceMask("L0",-1,0x9)
st.cmd line 24: Command asynSetTraceMask not found.
## Load record instances
#dbLoadRecords("db/xxx.db","user=osiloskop")
dbLoadRecords("db/devTDK.db","P=tdk_lambda,R=Test,PORT=L0,A=0")
cd "/home/osiloskop/EPICS/IOCs/TDK/iocBoot/iocTDKtest"
iocInit
Starting iocInit
## EPICS R3.15.8.1-DEV
## EPICS Base built Jun 22 2021
2021/06/22 14:22:33.738076 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestIDN'
2021/06/22 14:22:33.738776 _main_ tdk_lambdaTestIDN:
Can't attach to bus L0 0
2021/06/22 14:22:33.739342 _main_ tdk_lambdaTestIDN:
Record initialization failed
2021/06/22 14:22:33.739909 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestIDNwf'
2021/06/22 14:22:33.740447 _main_ tdk_lambdaTestIDNwf:
2021/06/22 14:22:33.740981 _main_ tdk_lambdaTestIDNwf:
2021/06/22 14:22:33.741510 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestGetSTB'
2021/06/22 14:22:33.742124 _main_ tdk_lambdaTestGetSTB:
2021/06/22 14:22:33.742664 _main_ tdk_lambdaTestGetSTB:
2021/06/22 14:22:33.743210 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestGetESR'
2021/06/22 14:22:33.743758 _main_ tdk_lambdaTestGetESR:
2021/06/22 14:22:33.744297 _main_ tdk_lambdaTestGetESR:
2021/06/22 14:22:33.744844 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestGetESE'
2021/06/22 14:22:33.745381 _main_ tdk_lambdaTestGetESE:
2021/06/22 14:22:33.746009 _main_ tdk_lambdaTestGetESE:
2021/06/22 14:22:33.746585 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestGetSRE'
2021/06/22 14:22:33.747116 _main_ tdk_lambdaTestGetSRE:
2021/06/22 14:22:33.747660 _main_ tdk_lambdaTestGetSRE:
2021/06/22 14:22:33.748211 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestGetOPC'
2021/06/22 14:22:33.748760 _main_ tdk_lambdaTestGetOPC:
2021/06/22 14:22:33.749291 _main_ tdk_lambdaTestGetOPC:
2021/06/22 14:22:33.749879 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestSetESE'
2021/06/22 14:22:33.750409 _main_ tdk_lambdaTestSetESE:
2021/06/22 14:22:33.750946 _main_ tdk_lambdaTestSetESE:
2021/06/22 14:22:33.751492 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestSetSRE'
2021/06/22 14:22:33.752026 _main_ tdk_lambdaTestSetSRE:
2021/06/22 14:22:33.752555 _main_ tdk_lambdaTestSetSRE:
2021/06/22 14:22:33.753122 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestRST'
2021/06/22 14:22:33.753600 _main_ tdk_lambdaTestRST:
2021/06/22 14:22:33.754200 _main_ tdk_lambdaTestRST:
2021/06/22 14:22:33.754888 _main_ Cannot find a bus named
'L0' for 'tdk_lambdaTestCLS'
2021/06/22 14:22:33.755377 _main_ tdk_lambdaTestCLS:
2021/06/22 14:22:33.755955 _main_ tdk_lambdaTestCLS:
## Start any sequence programs
#seq sncxxx,"user=osiloskop"
epics> help
Type 'help <command>' to see the arguments of
<command>.
# ClockTime_Report
ClockTime_Shutdown
asDumpHash asInit
asSetFilename asSetSubstitutions
ascar asdbdump
asphag aspmem asprules
aspuag astac
callbackParallelThreads
callbackSetQueueSize casr
cd coreRelease date
dbDumpBreaktable
dbDumpDevice dbDumpDriver dbDumpField
dbDumpFunction dbDumpMenu
dbDumpPath dbDumpRecord
dbDumpRecordType
dbDumpRegistrar dbDumpVariable dbLoadDatabase
dbLoadRecords dbLoadTemplate
dbLockShowLocked dbNotifyDump
dbPutAttribute dbPvdDump
dbPvdTableSize dbReportDeviceConfig
dbStateClear dbStateCreate
dbStateSet dbStateShow dbStateShowAll
dba dbap
dbb dbc dbcar
dbd dbel
dbgf dbgrep dbhcr
dbior dbl
dbla dblsr dbnr
dbp dbpf
dbpr dbs dbsr
dbstat dbtgf
dbtpf dbtpn dbtr
echo eltc epicsEnvSet
epicsEnvShow epicsEnvUnset
epicsMutexShowAll epicsParamShow
epicsPrtEnvParams
epicsThreadResume epicsThreadShow
epicsThreadShowAll
epicsThreadSleep errlog
errlogInit errlogInit2
exit generalTimeReport
gft help
installLastResortEventProvider iocBuild
iocInit iocLogInit
iocLogPrefix iocLogShow iocPause
iocRun iocshCmd
iocshLoad iocshRun pft
postEvent pwd
registryDeviceSupportFind
registryDriverSupportFind registryDump
registryFunctionFind
registryRecordTypeFind
scanOnceSetQueueSize scanpel
scanpiol scanppl
setIocLogDisable streamReinit
streamReload
streamReportRecord
streamSetLogfile taskwdShow
tpn var
epics> drvAsynSerialPortConfigure
Port name missing.
epics> drvAsyn
Command drvAsyn not found.
epics> asynReport(10,SERIALPORT)
Command asynReport not found.
epics> dbior "stream"
Driver: stream
StreamDevice 2.8.19-dirty 2021-04-09 17:41:57 +0200
commit: 377d511c670193c5d49493ebcb5e7385fb34440a
(C) 1999 Dirk Zimoch ([email protected])
Use interest level 100 for license information
registered bus interfaces:
DebugInterface
DummyInterface
AsynDriverInterface
~/EPICS/IOCs/TDK/dbd$ grep -i stream TDKtest.dbd
device(stringin, INST_IO, devstringinStream, "stream")
device(stringout, INST_IO, devstringoutStream, "stream")
device(aao, INST_IO, devaaoStream, "stream")
device(mbbi, INST_IO, devmbbiStream, "stream")
device(bi, INST_IO, devbiStream, "stream")
device(waveform, INST_IO, devwaveformStream, "stream")
device(ao, INST_IO, devaoStream, "stream")
device(lso, INST_IO, devlsoStream, "stream")
device(mbbiDirect, INST_IO, devmbbiDirectStream,
"stream")
device(longin, INST_IO, devlonginStream, "stream")
device(ai, INST_IO, devaiStream, "stream")
device(aai, INST_IO, devaaiStream, "stream")
device(longout, INST_IO, devlongoutStream, "stream")
device(mbbo, INST_IO, devmbboStream, "stream")
device(bo, INST_IO, devboStream, "stream")
device(mbboDirect, INST_IO, devmbboDirectStream,
"stream")
device(lsi, INST_IO, devlsiStream, "stream")
device(calcout, INST_IO, devcalcoutStream, "stream")
driver(stream)
registrar(streamRegistrar)
variable(streamDebug, int)
variable(streamDebugColored, int)
variable(streamError, int)
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc
noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu
1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 08:00:27:48:94:10 brd ff:ff:ff:ff:ff:ff
inet 10.0.2.15/24 brd 10.0.2.255 scope global dynamic
enp0s3
valid_lft 67195sec preferred_lft 67195sec
inet6 fe80::a00:27ff:fe48:9410/64 scope link
3: enp0s8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu
link/ether 70:54:d2:db:d2:d4 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7254:d2ff:fedb:d2d4/64 scope link
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu
1500 qdisc noqueue state DOWN group default
link/ether 02:42:ce:4a:e5:26 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global
docker0
$tail -5 ~/.bashrc
export EPICS_BASE=${HOME}/EPICS/epics-base
export
EPICS_HOST_ARCH=$(${EPICS_BASE}/startup/EpicsHostArch)
export PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
export ASYN=${HOME}/EPICS/support/asyn
export EPICS_DISPLAY_PATH=${ASYN}/opi/medm
~/EPICS/IOCs/TDK/dbd$ less
../../../support/asyn/configure/RELEASE
#RELEASE Location of external products
SUPPORT=/home/osiloskop/EPICS/support
# IPAC is only necessary if support for Greensprings
IP488 is required
# IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-15
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-2-5
## For sCalcout support in asynOctet - applications
include asynCalc.dbd
#CALC=$(SUPPORT)/calc-3-7-3
# If CALC was built with SSCAN support then SSCAN must be
defined for testEpicsApp
#SSCAN=$(SUPPORT)/sscan-2-11-3
# EPICS_BASE 3.14.6 or later is required
EPICS_BASE=/home/osiloskop/EPICS/epics-base
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
less ../../../support/StreamDevice/configure/RELEASE
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=${HOME}/EPICS/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/asyn
#PCRE=$(SUPPORT)/pcre-7-2
# EPICS_BASE usually appears last so other apps can
override stuff:
# These lines allow developers to override these RELEASE
settings
# without having to modify this file directly.
Thank you for your help in the future.
Best regards.
Hasan Sansar
Re: Using autosave to restore device settings after a reset without rebooting IOC Ralph Lange via Tech-talk
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
