Subject: questions about the motor homing sequence
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Tue, 29 Jun 2021 15:13:26 +0000
Hello EPICS-community,
I'm trying to write an EPICS-motor device support for the PEGASUS Rotation- and Linear-Stages from Micos. I'm using the Hydra and Corvus motor-support from the main EPICS-motor module as a template.
I have the following problem when writing the homing sequence for the Rotation-stages: after sending the homing-command string
    sprintf(pC_->outString_, "1 0 %i setsw 1 1 %i setsw 1 0 %i sncal", (axisNo_ + 1), (axisNo_ + 1), (axisNo_ + 1));
    pC_->writeController();
I need to wait until reference-drive finished aka. the motor stopped, so I can switch off the Limit-switches with the following command:
    sprintf(pC_->outString_, "2 0 %i setsw 2 1 %i setsw", (axisNo_ + 1), (axisNo_ + 1));
So far I could resolve this problem by implementing a while loop with an epicsThreadSleep(1.) asking the controller about its moving bit and once it set to 1 (done), execute the desired command. Here is my complete code of the homing function:
asynStatus SMCpegasusAxis::home(double baseVelocity, double slewVelocity, double acceleration, int forwards)
  asynStatus status;
  int done = 0;
  int axisStatus = -1;
  double position = 0.0;
  // static const char *functionName = "SMCpegasusAxis::home";
  status = sendAccelAndVelocity(acceleration, slewVelocity);
  if (forwards) {
    // Read the status of this motor
    sprintf(pC_->outString_, "%i nst", (axisNo_ + 1));
    pC_->writeReadController();
    // The response string is an int
    axisStatus = atoi( (char *) &pC_->inString_);
    do
        // Read the current motor position
        sprintf(pC_->outString_, "%i np", (axisNo_ + 1));
        // The response string is a double
        position = atof( (char *) &pC_->inString_);
        setDoubleParam(pC_->motorPosition_, (position / axisRes_) );
        setDoubleParam(pC_->motorEncoderPosition_, (position / axisRes_) );
        // Check the moving bit
        done = !(axisStatus & 0x1);
        setIntegerParam(pC_->motorStatusDone_, done);
        setIntegerParam(pC_->motorStatusMoving_, !done);
        epicsThreadSleep(1.);
    } while (done == 0);
    //epicsThreadSleep(3.);
  } else {
    //still ToDo the Home Run backward
  status = pC_->writeController();
  return status;
Having a while-loop with an threadSleep is kind of bad coding I think, so I'm wondering if someone knows a better solution?
PS: I'm also trying to update the motor position during the while-loop (it is the "// Read the current motor position" passage). I see the correct position in the asyn communication but the .RBV value of the motor record won't update. I guess, this can only be done from the poll-function?
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Prev: areaDetector ADEiger R3-0 released Mark Rivers via Tech-talk
Next: Re: questions about the motor homing sequence Mark Rivers via Tech-talk
