Subject: Re: porting IOCs from Linux to RTEMS
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, "[email protected]" <[email protected]>, "Siddons, David" <[email protected]>
Date: Tue, 29 Jun 2021 21:00:28 +0000
Hi Pete,
I think Kiman Ha did that to make copies of softGlueZynq run at NSLS (because someone wanted to use the scaler in softGlueZynq).  As far as I know, Kiman's solution boots from the MicroSD card and autostarts an EPICS IOC.  You can run the EPICS IOC with or without softGlueZynq.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Tuesday, June 29, 2021 3:51 PM
To: EPICS Tech Talk <[email protected]>; [email protected] <[email protected]>
Subject: porting IOCs from Linux to RTEMS
I need to build an EPICS IOC which can run without access to NFS mounts or TFTP mounts. The embedded system is a ZynQ-based system with ample persistent storage on a micro-SD card. It seems to me that libbsd provides a full range of file I/O facilities, and so a more Linux-like configuration should be possible. But I have no idea how to accomplish this! I suspect that I need to change ~/epics/base-7.0/modules/libcom/RTEMS/posix/rtems_init.c, since that seems to be where the NFS/TFTP stuff gets set up. Has anyone tried to do this?
Pete.
Re: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
Prev: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
Next: Re: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
