I need to build an EPICS IOC which can run without access to NFS mounts or TFTP mounts. The embedded system is a ZynQ-based system with ample persistent storage on a micro-SD card. It seems to me that libbsd provides a full range of file I/O facilities, and
so a more Linux-like configuration should be possible. But I have no idea how to accomplish this! I suspect that I need to change ~/epics/base-7.0/modules/libcom/RTEMS/posix/rtems_init.c, since that seems to be where the NFS/TFTP stuff gets set up. Has anyone
tried to do this?
Pete.
- Re: porting IOCs from Linux to RTEMS Mooney, Tim M. via Tech-talk
Re: questions about the motor homing sequence Mark Rivers via Tech-talk
<2021>
2025
2026
AW: questions about the motor homing sequence Sintschuk, Michael via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
