Subject: AW: questions about the motor homing sequence
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Mon, 12 Jul 2021 16:19:21 +0000
Hi Mark,
I forgot to reply to all the last time, so I copy pasted your solution into this mail.
Yes, your second solution works quite well. Even though I put the " homingInProgress " variable into the header file. I pushed it to git:
https://github.com/MichaS-git/motorMicos
but it is the very first version and still needs further development and testing.
Thanks for the explanation!
Michael
>However, it works to compile with "pC_->lock();" and "pC_->unlock();". But it has no effect on the record-update.
Yes, my mistake.  You need to use pC_->lock()/unlock().
To create a new thread you need to call epicsThreadCreate().  You pass it the address of a function to be called, and a void* pointer, which in this case would be “this”.
However, I just realized there is probably a simpler way to solve this problem.
-	In your SMCpegasusAxis class create a new private bool variable called homingInProgress or something like that.
-	In SMCpegasusAxis::home only do the following:
o	set that homingInProgress variable to true
o	Start the homing operation
-	Change your SMCpegasusAxis::poll() routine so it does the following:
o	If homingInProgress is true, and if the motor makes the transition from moving to not moving (homing is complete) then do the following:
	Set homingInProgress to false
	Send the string that needs to be sent to the controller when homing is complete
Does that seem like it would work?
Sent: Wednesday, June 30, 2021 8:18 AM
To: Mark Rivers
Hi Mark,
> You can take that code and run it in a separate thread.  You need to call lock() on entrance, and then release the lock around the sleep.
By calling lock() the separate thread is created or do I need to write the separate thread by my own, like a separate function? (sorry, I'm new to c++ )
When I try to compile my code with the the "lock();" and "unlock();" lines I get the error: 'lock' was not declared in this scope.
Michael
-----Ursprüngliche Nachricht-----
Von: Mark Rivers <[email protected]>
Gesendet: Dienstag, 29. Juni 2021 18:13
An: Sintschuk, Michael <[email protected]>
Cc: [email protected]
Betreff: Re: questions about the motor homing sequence
Hi Michael,
> Having a while-loop with an threadSleep is kind of bad coding I think, so I'm wondering if someone knows a better solution?
unlock();
epicsThreadSleep(1);
lock();
> PS: I'm also trying to update the motor position during the while-loop (it is the "// Read the current motor position" passage). I see the correct position in the asyn communication but the .RBV value of the motor record won't update. I guess, this can only be done from the poll-function?
The poller should continue to run normally if you run the home sequence in a separate thread and call unlock() as shown above.
From: Tech-talk <[email protected]> on behalf of Sintschuk, Michael via Tech-talk <[email protected]>
Sent: Tuesday, June 29, 2021 10:13 AM
To: [email protected]
Subject: questions about the motor homing sequence
Hello EPICS-community,
I'm trying to write an EPICS-motor device support for the PEGASUS Rotation- and Linear-Stages from Micos. I'm using the Hydra and Corvus motor-support from the main EPICS-motor module as a template.
I have the following problem when writing the homing sequence for the Rotation-stages: after sending the homing-command string
    sprintf(pC_->outString_, "1 0 %i setsw 1 1 %i setsw 1 0 %i sncal", (axisNo_ + 1), (axisNo_ + 1), (axisNo_ + 1));
    pC_->writeController();
I need to wait until reference-drive finished aka. the motor stopped, so I can switch off the Limit-switches with the following command:
    sprintf(pC_->outString_, "2 0 %i setsw 2 1 %i setsw", (axisNo_ + 1), (axisNo_ + 1));
So far I could resolve this problem by implementing a while loop with an epicsThreadSleep(1.) asking the controller about its moving bit and once it set to 1 (done), execute the desired command. Here is my complete code of the homing function:
asynStatus SMCpegasusAxis::home(double baseVelocity, double slewVelocity, double acceleration, int forwards) {
  asynStatus status;
  int done = 0;
  int axisStatus = -1;
  double position = 0.0;
  // static const char *functionName = "SMCpegasusAxis::home";
  status = sendAccelAndVelocity(acceleration, slewVelocity);
  if (forwards) {
    // Read the status of this motor
    sprintf(pC_->outString_, "%i nst", (axisNo_ + 1));
    pC_->writeReadController();
    // The response string is an int
    axisStatus = atoi( (char *) &pC_->inString_);
    do
        sprintf(pC_->outString_, "%i np", (axisNo_ + 1));
        // The response string is a double
        position = atof( (char *) &pC_->inString_);
        setDoubleParam(pC_->motorPosition_, (position / axisRes_) );
        setDoubleParam(pC_->motorEncoderPosition_, (position / axisRes_) );
        // Check the moving bit
        done = !(axisStatus & 0x1);
        setIntegerParam(pC_->motorStatusDone_, done);
        setIntegerParam(pC_->motorStatusMoving_, !done);
        epicsThreadSleep(1.);
    } while (done == 0);
    //epicsThreadSleep(3.);
  } else {
    //still ToDo the Home Run backward
  status = pC_->writeController();
  return status;
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]<mailto:[email protected]>
questions about the motor homing sequence Sintschuk, Michael via Tech-talk
Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Prev: Re: Kubernetes for EPICS IOCs Josh Fiddler via Tech-talk
Next: Re: Event Recordings -- Epics Spring 2021 Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: questions about the motor homing sequence Mark Rivers via Tech-talk
Next: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
