Subject: Getting severity string from a PV in recent versions of EPICS
From: "Sobhani, Bayan via Tech-talk" <[email protected]>
Date: Wed, 30 Jun 2021 16:07:54 +0000
After upgrading EPICS, I started getting this message for some PVs:
missing record support entry table Record Support Routine (get_enum_str) Record Type ai PV XF:28ID1-CT{RG:B1}T-I.SEVR  dbGetField
It seems to be because I am converting an enum to a string in:
field(INPA, "$(Sys)$(Dev)T$(N_T)-I.SEVR")
field(FTA, "STRING")
This used to work in previous versions of EPICS, and in fact I can get the problem to go away if I read the PV over channel access, like: "$(Sys)$(Dev)T$(N_T)-I.SEVR CP”
So I am wondering: What is the recommended way to get the severity string from a PV in recent versions of EPICS?
Alex
Re: Getting severity string from a PV in recent versions of EPICS Johnson, Andrew N. via Tech-talk
Prev: Re: porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
Next: Re: Getting severity string from a PV in recent versions of EPICS Johnson, Andrew N. via Tech-talk
