Subject: Re: Getting severity string from a PV in recent versions of EPICS
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Sobhani, Bayan" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 30 Jun 2021 17:53:35 +0000
Hi Alex,
On Jun 30, 2021, at 11:07 AM, Sobhani, Bayan via Tech-talk <[email protected]> wrote:
After upgrading EPICS, I started getting this message for some PVs:
missing record support entry table Record Support Routine (get_enum_str) Record Type ai PV XF:28ID1-CT{RG:B1}T-I.SEVR  dbGetField
It seems to be because I am converting an enum to a string in:
field(INPA, "$(Sys)$(Dev)T$(N_T)-I.SEVR")
field(FTA, "STRING")
This used to work in previous versions of EPICS, and in fact I can get the problem to go away if I read the PV over channel access, like: "$(Sys)$(Dev)T$(N_T)-I.SEVR CP”
So I am wondering: What is the recommended way to get the severity string from a PV in recent versions of EPICS?
That should work as you expected using a DB link, but it seems to have been broken by some recent changes to the IOC on the 7.0 branch (it’s fine in 7.0.4, not sure about 7.0.4.1):
woz$ cat ~/db/test.db
record(ai, "ai") {}
record(stringin, "si") {
  field(INP, "ai.SEVR")
woz$ ./base-3.15/bin/darwin-x86/softIoc -d ~/db/test.db
Starting iocInit
## EPICS R3.15.9
## EPICS Base built Jun 30 2021
epics> dbpf si.PROC 1
DBR_UCHAR:          1         0x1
epics> dbgf si
DBR_STRING:          "INVALID"
epics> woz$
woz$ ./base-7.0/bin/darwin-x86/softIoc -d ~/db/test.db
Starting iocInit
## EPICS R7.0.5.1-DEV
## Rev. R7.0.5-264-g7ca25d3c888c56844877-dirty
missing record support entry table Record Support Routine (get_enum_str) Record Type ai PV ai.SEVR  dbGetField
DBF_UCHAR:          1 = 0x1
I’m pretty sure I know where the problem came from, in the mean-time your CA work-around is probably the best solution, until we can ship a fix.
Thanks for the bug report, I have filed it as an issue in GitHub.
- Andrew
Complexity comes for free, simplicity you have to work for.
Getting severity string from a PV in recent versions of EPICS Sobhani, Bayan via Tech-talk
Prev: Getting severity string from a PV in recent versions of EPICS Sobhani, Bayan via Tech-talk
Next: EPICS interface for Edwards nXDS scroll pump Raymond Juras via Tech-talk
