Subject: Re: EPICS compilation
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Adrian Martinez <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 1 Jul 2021 16:20:05 +0200
It seems as if you link a record to an asyn-parameter,
that does not exist.
If I understand that right, the Record "SL-SCL-CM1:LRF-EC-1:UCavMinRd"
"links/connects" to the asyn parameter "ucav_min_sw" - but can not find it, when the record is loaded/initialized.
On 7/1/21 4:15 PM, Adrian Martinez via Tech-talk wrote:
Hello,
I am using epics R3.15.5 and most builds are not correct. In fact, the compilation is always successful but a lot of process variables (usually binary PVs) do not have their readback available and I get these errors when I run the IOC:
*Starting iocInit
## EPICS R3.15.5
## EPICS Base built Jun 24 2021
2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ucav_min_sw
SL-SCL-CM1:LRF-EC-1:UCavMinRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter uci_min_sw
SL-SCL-CM1:LRF-EC-1:UCiMinRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter dump_meas_delay
SL-SCL-CM1:LRF-EC-1:DumpMeasDelayRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter pm_sp_rate
SL-SCL-CM1:LRF-EC-1:PmSpRateRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter pm_meas_delay
SL-SCL-CM1:LRF-EC-1:PmMeasDelayRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter samp_dur
SL-SCL-CM1:LRF-EC-1:PmSpDurRd devAsynInt32::initCommon drvUserCreate
2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ff_gain_i
SL-SCL-CM1:LRF-EC-1:FfGainIRd devAsynFloat64::initCommon drvUserCreate
2021/06/30 09:14:18.938 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ff_gain_q
SL-SCL-CM1:LRF-EC-1:FfGainQRd devAsynFloat64::initCommon drvUserCreate *
Has anyone gotten these same errors?
  Thanks in advance, Adrián.
*Adrián Martínez*
Embedded Software Engineer
	Seven Solutions
Mail: [email protected] <mailto:[email protected]>
www.sevensols.com <http://www.sevensols.com/>
 This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
EPICS compilation Adrian Martinez via Tech-talk
Prev: EPICS compilation Adrian Martinez via Tech-talk
Next: Question about "error calling writeRead" in modbus Wang, SuYin Grass via Tech-talk
Next: RE: EPICS compilation Mark Rivers via Tech-talk
