Hello,
I am using epics R3.15.5 and most builds are not correct. In fact, the compilation is always successful but a lot of process variables (usually binary PVs) do not have their readback available and I get these errors when I run the IOC: Starting iocInit ############################################################################ ## EPICS R3.15.5 ## EPICS Base built Jun 24 2021 ############################################################################ 2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ucav_min_sw SL-SCL-CM1:LRF-EC-1:UCavMinRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter uci_min_sw SL-SCL-CM1:LRF-EC-1:UCiMinRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter dump_meas_delay SL-SCL-CM1:LRF-EC-1:DumpMeasDelayRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.936 asynPortDriver:drvUserCreate: addr=0, cannot find parameter pm_sp_rate SL-SCL-CM1:LRF-EC-1:PmSpRateRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter pm_meas_delay SL-SCL-CM1:LRF-EC-1:PmMeasDelayRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter samp_dur SL-SCL-CM1:LRF-EC-1:PmSpDurRd devAsynInt32::initCommon drvUserCreate 2021/06/30 09:14:18.937 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ff_gain_i SL-SCL-CM1:LRF-EC-1:FfGainIRd devAsynFloat64::initCommon drvUserCreate 2021/06/30 09:14:18.938 asynPortDriver:drvUserCreate: addr=0, cannot find parameter ff_gain_q SL-SCL-CM1:LRF-EC-1:FfGainQRd devAsynFloat64::initCommon drvUserCreate Has anyone gotten these same errors? Thanks in advance, Adrián.
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
