Subject: Re: Using CALC value to set NELM in subArray
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 1 Jul 2021 15:31:39 +0000
Hi Andy,
On Jun 30, 2021, at 9:01 PM, Wang, Andrew via Tech-talk <[email protected]> wrote:
I want to use a calc record to determine what I want my NELM in a subArray record to be. I keep getting an error saying that there are no digits to convert. I feel like the problem is because the NELM field is ULONG, while the VAL field of the calc record is a DOUBLE. Don’t think it is possible to “cast” the DOUBLE to a ULONG in the calc record, unless I am wrong. Is there a way around this or is the best approach to use an aSub record?
The VAL field of a calc record holds a double, so even if you could cast the value in the _expression_ it would still be represented as a double result after the calculation was complete.
How are you copying your calc.VAL field value to the subArray.NELM field? I suspect that’s where your problem may be, are you trying to use NELM as a link? That would generate the “no digits to convert” error because NELM is a DBF_ULONG field so you can only set it to an integer numeric value in your .db file. Only DBF_LINK fields can point to other PVs. To copy the calc result into it I would use a calcout record and point its OUT link (which is a DBF_OUTLINKfield ) to the NELM field so its value will be copied.
If I’ve misunderstood what you’re doing, please post your .db file and the exact error message you’re getting; explicit examples are always much easier to debug than descriptions.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
Prev: Question about "error calling writeRead" in modbus Wang, SuYin Grass via Tech-talk
Next: RE: EPICS compilation Mark Rivers via Tech-talk
Prev: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
Next: Re: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
