Subject: |
Using CALC value to set NELM in subArray |
"Wang, Andrew via Tech-talk" <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Thu, 1 Jul 2021 02:01:54 +0000 |
Quick question,
I want to use a calc record to determine what I want my NELM in a subArray record to be. I keep getting an error saying that there are no digits to convert. I feel like the problem is because the NELM field is ULONG, while the VAL field
of the calc record is a DOUBLE. Don’t think it is possible to “cast” the DOUBLE to a ULONG in the calc record, unless I am wrong. Is there a way around this or is the best approach to use an aSub record?
Andy
- Re: Using CALC value to set NELM in subArray Johnson, Andrew N. via Tech-talk
Re: EPICS interface for Edwards nXDS scroll pump Florian Feldbauer via Tech-talk
Accessing the "opi_file" property of the Linking Container 工藤真由子 via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
