Subject: Re: EPICS interface for Edwards nXDS scroll pump
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Raymond Juras <[email protected]>, [email protected]
Date: Wed, 30 Jun 2021 23:27:39 +0200
Hey Ray,
we are using an nXDS scroll pump from edwards and controll it via StreamDevice + Asyn via the RS485 interface.
I've attached protocol and database files.
HTH,
Cheers,
Florian
On 6/30/21 10:50 PM, Raymond Juras via Tech-talk wrote:
Hello,
Has anyone developed an EPICS interface to the Edwards nXDS scroll pump?
Thank you,
Ray Juras
Oak Ridge National Laboratory
email: [email protected]
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
# ### EPICS Database for                ### #
# ### Edwards nXDS 15i                  ### #
# ### author: R.Kieser                  ### #
# ### Ref 1.0; 2014-01-06               ### #
# ### macros: subsys  PANDA subsystem   ### #
# ###         PORT    Asyn Interface    ### #
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:Tmom") {
  field (DTYP, "stream")
  field (INP,  "@Edwards_nXDS15i.proto getTemperature $(PORT)")
# field (SCAN, "10 second")
  field (FLNK, "PANDA:$(subsys):VACUUM:FOREPUMP:Mfrequency")
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:MotorFreqMom") {
  field (INP,  "@Edwards_nXDS15i.proto getMfrequency(PANDA:$(subsys):VACUUM:FOREPUMP) $(PORT)")
  field (FLNK, "PANDA:$(subsys):VACUUM:FOREPUMP:getRunTime")
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Statusregister1") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Statusregister2") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Warnings") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:faultregister") {
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:getError") {
  field (INP,  "@Edwards_nXDS15i.proto getError $(PORT)")
  field (PINI, "YES")
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:getRunTime") {
  field (INP,  "@Edwards_nXDS15i.proto getRunTime $(PORT)")
# field (SCAN, "300 second")
record (bo , "PANDA:$(subsys):VACUUM:FOREPUMP:Pump") {
  field (OUT,  "@Edwards_nXDS15i.proto Pump $(PORT)")
  field (ZNAM, "OFF" )
  field (ONAM, "ON" )
# ### StreamDevice Protocol for             ### #
# ### Ref 1.0; 2013-12-19                   ### #
# ### Globals ### #
Terminator    = CR;
LockTimeout   = 5000;
ReplyTimeout  = 500;
ReadTimeout   = 500;
WriteTimeout  = 300;
ExtraInput    = Ignore;
# ### Protocols ### #
getTemperature {
  # get measured pump temperature
  # Example of command:
  # field (INP, "@Edwards_nxDS15i.proto getTemperature $(PORT)")
  out "?V808";
  in  "=V808 %u";
getMfrequency {
  # get motor frequncy and status words
  # field (INP, "@Edwards_nxDS15i.proto getMfrequency(PANDA:$(subsys):VACUUM) $(PORT)")
  out "?V802";
  in  "=V802 %u;%(\$1:Statusregister1)x;%(\$1:Statusregister2)x;%(\$1:Warnings)x;%(\$1:faulregister)x";
getError {
  # get fault history at last trip
  # field (INP, "@Edwards_nxDS15i.proto getError(PANDA:$(subsys):VACUUM) $(PORT)")
  out "?V816";
  in  "=V816 %x;%x;%x;%x";
getRunTime {
  # get Total run hours - time pump has run
  # field (INP, "@Edwards_nxDS15i.proto getRunTime $(PORT)")
  out "?V810";
  in  "=V810 %u";
Pump {
  # switch forepump on/off
  # field (OUT, "@Edwards_nxDS15i.proto Pump $(PORT)")
  out "!C802 %u";
  in  "*C802 %*u";
#  @init {
#    out "in_mode_05";
#    in  DC3,"%i";
EPICS interface for Edwards nXDS scroll pump Raymond Juras via Tech-talk
Prev: EPICS interface for Edwards nXDS scroll pump Raymond Juras via Tech-talk
Next: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
