Subject: CALC record LINK INVALID status
To: Michael Davidsaver via Tech-talk <[email protected]>
Date: Sat, 3 Jul 2021 15:23:53 -0700
Base R3.15.7     ASYN R4-38
My intent is to push output record values to an attached FPGA when the FPGA powers up or when communication to the FPGA is restored.  To do this I have a periodically-scanned record that monitors the FPGA power-up status and a CALC record that attempts to detect communication restoration or FPGA power-up:
# Value of this record is the FPGA power-up status.
record(bi, "$(P)$(R)FPGA:Powerup") {
    field(DESC, "Trigger sysmon read. FPGA power-up?")
    field(DTYP, "asynInt32")
    field(INP,  "@asyn($(PORT) 0x0000 0)")
    field(SCAN, "2 second")
    field(ZNAM, "Not restarted")
    field(ONAM, "Restarted")
    field(FLNK, "$(P)$(R)IOC:reconChk_")
# Monitor the status of the FPGA power-up status record (B) to detect
# reconnection and monitor the value (A) to detect FPGA power up.
# Push output record values to FPGA when required.
record(calcout, "$(P)$(R)IOC:reconChk_") {
    field(DESC, "Trigger push on reconnect or power up")
    field(INPA, "$(P)$(R)FPGA:Powerup NPP NMS")
    field(INPB, "$(P)$(R)FPGA:Powerup.STAT NPP NMS")
    field(INPC, "0")
    field(CALC, "B=0&&((C!=0)||A);C:=B")
    field(OOPT, "When Non-zero")
    field(TPRO, 1)
    field(OUT,  "$(P)$(R)IOC:recon_.PROC")
record(fanout, "$(P)$(R)IOC:reconA_") {
    field(PINI, "YES”)
. . . Here’s where I have the LNKx records that trigger output record processing . . .
    field(FLNK, “$(P)$(R)IOC:clrPwrup_")
record(longout, "$(P)$(R)IOC:clrPwrup_") {
    field(DESC, "Clear FPGA power-up status")
    field(OUT,  "@asyn($(PORT) 0x1000 0)")
But this doesn’t seem to work.  When communication is broken and restored (the ‘Dalesio Test’) the calcout record is in a weird state.  The problem is illustrated by monitoring a few things:
camonitor TEST:IOC:reconChk_ TEST:IOC:reconChk_.A TEST:IOC:reconChk_.B TEST:FPGA:Powerup
TEST:IOC:reconChk_         2021-07-03 14:57:04.957026 0
TEST:IOC:reconChk_.A       2021-07-03 14:57:04.957026 0
TEST:IOC:reconChk_.B       2021-07-03 14:57:04.957026 0
TEST:FPGA:Powerup          2021-07-03 14:57:04.957004 Not restarted
<<<< Here’s where I unplugged the network cable >>>>>
TEST:FPGA:Powerup          2021-07-03 14:57:11.573206 Not restarted READ INVALID
TEST:IOC:reconChk_.B       2021-07-03 14:57:11.573230 1
<<<<< Here’s where I reconnected the network cable >>>>>
TEST:FPGA:Powerup          2021-07-03 14:57:24.957220 Not restarted
TEST:IOC:reconChk_         2021-07-03 14:57:24.957249 1 LINK INVALID     <<<<< Why is this happening? Link has NMS
TEST:IOC:reconChk_.A       2021-07-03 14:57:24.957249 0 LINK INVALID
TEST:IOC:reconChk_.B       2021-07-03 14:57:24.957249 0 LINK INVALID
TEST:IOC:reconChk_         2021-07-03 14:57:26.957653 0
TEST:IOC:reconChk_.A       2021-07-03 14:57:26.957653 0
TEST:IOC:reconChk_.B       2021-07-03 14:57:26.957653 0
So even though the CALC record value is non-zero, the value isn’t pushed to the OUT link and the fanout and assorted downstream records don’t process.
I tried with OOPT=“Transition To Zero” and got the same result.
Why is the CALC record going into LINK INVALID state?  Do I misunderstand what NMS is supposed to do?
Eric Norum
Prev: Segmentation fault when Gateway calls ca_clear_channel: removing node from empty createReqPend linked list Paduan Donadio, Marcio via Tech-talk
Next: Re: EPICS compilation Adrian Martinez via Tech-talk
Next: pythonIoc is now a python package rather than an EPICS support module Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
