Dear Matt, I have applied the following 2 patches to autosave: Attachment:
patch2.diff Attachment:
patch1.diff Heinz > On 13. Jul 2021, at 07:52, Matt Rippa via Tech-talk <[email protected]> wrote: > > Hello, > > Our builds of autosave [1] using RTEMS 4.10.2 and EPICS 3.15.x have a warning of an implicit call to nfsMount(). Despite this nfsMount() works fine on iocBoot. > In EPICS 7.0.6 and RTEMS5 there's a rule to halt on warning when building autosave. I searched tech-talk and [2] looks similar, moving from RTEMS 4.9 to 4.10. > > Build host is CentOS-8, RTEMS-mvme2700 (aka 2307) with details in [2]. But the implicit warning also happens on RTEMS-mvme3100 and RTEMS-beatnik. > > /home/mrippa/MVME2307/rtems/5/bin/powerpc-rtems5-gcc --pipe -B/home/mrippa/MVME2307/rtems/5/powerpc-rtems5/mvme2307/lib/ -specs bsp_specs -qrtems -fasm -mcpu=604 -mmultiple -mstring -mstrict-align -meabi -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUNIX -O2 -g -ffunction-sections -fdata-sections -Wall -Werror-implicit-function-declaration -DUSE_TYPED_RSET -DDBLOADRECORDSHOOKREGISTER -DMY_DO_BOOTP=NULL -DHAVE_PPCBUG -DNVRAM_INDIRECT -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK -I. -I../O.Common -I. -I. -I../os/RTEMS -I../os/default -I.. -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include -I/home/mrippa/work/vendor/epics-base/include/compiler/gcc -I/home/mrippa/work/vendor/epics-base/include/os/RTEMS -I/home/mrippa/work/vendor/epics-base/include -c ../os/RTEMS/osdNfs.c > ../os/RTEMS/osdNfs.c: In function 'mountFileSystem': > ../os/RTEMS/osdNfs.c:45:9: error: implicit declaration of function 'nfsMount'; did you mean 'nfsInit'? [-Werror=implicit-function-declaration] > if (nfsMount(uidhost, path, mntpoint) == OK) { /* 0 - succeed; -1 - failed */ > ^~~~~~~~ > nfsInit > cc1: some warnings being treated as errors > make[3]: *** [/home/mrippa/work/vendor/epics-base/configure/RULES_BUILD:259: osdNfs.o] Error 1 > > Is there something off with my RTEMS or EPICS builds? > > Thanks, > -Matt > > [1] autosave https://github.com/epics-modules/autosave.git > [2] https://epics.anl.gov/tech-talk/2012/msg01045.php > [3] rtems5_epics7_build.txt (attached) > <rtems5_epics7_build.txt> Attachment:
smime.p7s
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
