Hi Scott,
I don’t know of areaDetector support for those Thorlabs cameras. I have looked at them before when others inquired about them. They have a few disadvantages
to be aware of:
They are not GenICam compliant, which means that ADAravis cannot be used with them.
The vendor SDK only supports Windows, so you cannot use Linux.
They only support rolling shutter, not global shutter. That means that each row of your image is acquired at a different time, they are not synchronous.
That may or may not be an issue for your application.
On Behalf Of Feister, Scott via Tech-talk
Sent: Wednesday, July 28, 2021 3:32 PM
To: EPICS tech-talk <[email protected]>
Subject: Drivers for Thorlabs camera, Gentec power meter?
Hi EPICS users,
I have two inquiries about current drivers:
- Is anyone currently using areaDetector for this Thorlabs camera:
Thorlabs CS2100M-USB (https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=11421)
- Is anyone using a driver with the Gentec S-Link-2-Ethernet power meter base station? (https://www.gentec-eo.com/products/s-link-2-ethernet)
- E.g. I found this from Marek Böhm in the archives of tech-talk:
https://epics.anl.gov/tech-talk/2015/msg00751.php
Thanks!
Scott
Scott Feister
Assistant Professor, California State University Channel Islands
- RE: Drivers for Thorlabs camera, Gentec power meter? Feister, Scott via Tech-talk
- Drivers for Thorlabs camera, Gentec power meter? Feister, Scott via Tech-talk
CA Gateway converts int/float value to hex andrej.manojlovic--- via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
