Subject: RE: New Radiation Monitor options [SEC=UNOFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <[email protected]>
To: "EPICS Tech Talk ([email protected])" <[email protected]>
Date: Thu, 29 Jul 2021 01:47:33 +0000
Hi Keith, Brendan,
At the Australian Synchrotron, in the end we went the Ludlum 375.
And we developed an EPICS Asyn Port driver which I am more than happy to share if you, if you select the Ludlum.
Regards
UNOFFICIAL
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Chandler, Brendan via Tech-talk
Sent: Thursday, 29 July 2021 5:59 AM
To: tech-talk <[email protected]>; Baker, Keith (DLSLtd,RAL,LSCI) <[email protected]>
Subject: Re: New Radiation Monitor options
CAUTION, EXTERNAL EMAIL: This message has come from a source outside of ANSTO. Do not take action, click links or open attachments unless you recognise and trust the source of this email and know the content is safe. Please report suspicious emails to [email protected] as an attachment.
Hi Keith,
At APS we've been evaluating the Thermo FHT6020 and I haven't seen the performance issues mentioned in the Australian Synchrotron thread.  I tried timing 100 requests to our FHT6020 device, alternating beween channels 1 and 2 each time, and it averaged 0.05 seconds per request, doing the entire 100 in about 5 seconds.  Maybe Thermo Fischer has updated the firmware or there was some other issue since then?
I've made a streamdevice based IOC to talk to the FHT6020 and could share with you if you're interested.  Similarly, I have a streamdevice IOC for the Mirion DRM-3000 radiation monitor if interested.
Brendan
From: Tech-talk <[email protected]> on behalf of Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>
Sent: Wednesday, July 28, 2021 10:36
To: tech-talk
Subject: New Radiation Monitor options
Hello,
We are looking at the Berthold LB6419 Neutron and Gamma Radiation Monitor as a possible replacement for our old obsolete ones.
I've been told these are in use at PETRA. Can anyone confirm that and has anyone already developed EPICS support for this model or similar?
I see that a similar message about new Radiation Monitors was posted by the Australian Synchrotron in 2018. I think the summary of responses was,
Health Physics Instruments (HPI) 6016 Area Radiation Monitors (Used in NSLS-II. Drivers available)
Thermo Scientific FHT 6020 (Drivers developed at SLAC and the FHI FEL, but the device is quite slow apparently. "read from multiple channels can take several seconds". I assume that means several values.) Ludlum 375 (No EPICS support mentioned.) Berthold (No EPICS support mentioned.)
Any other suggestions would be welcome.
Thanks.
Keith Baker
Diamond Light Source
Prev: Re: CA Gateway converts int/float value to hex Johnson, Andrew N. via Tech-talk
Next: RE: New Radiation Monitor options Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: CA Gateway converts int/float value to hex andrej.manojlovic--- via Tech-talk
Next: Stream device: Reading values from two almost identical input strings using I/O intr Nicklas Bjärnhall Prytz via Tech-talk
