Subject: Re: Stream device: Reading values from two almost identical input strings using I/O intr
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 29 Jul 2021 11:59:02 +0200
On Thu, 29 Jul 2021 at 11:55, Ralph Lange <[email protected]> wrote:
I think your best bet is to use a single format, write the number and the tag in two separate records, and FLNK a combination of calcout then seq to forward the number to where it belongs.
Three. (I missed the units.)
I think your best bet is to use a single format, write number, units and tag in three separate records, and FLNK a combination of calcout (on the tag) then seq (in mask mode) to forward number and unit where they belong.
~Ralph
Stream device: Reading values from two almost identical input strings using I/O intr Nicklas Bjärnhall Prytz via Tech-talk
Re: Stream device: Reading values from two almost identical input strings using I/O intr Ralph Lange via Tech-talk
Prev: Re: Stream device: Reading values from two almost identical input strings using I/O intr Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Next: Re: Stream device: Reading values from two almost identical input strings using I/O intr Zimoch Dirk (PSI) via Tech-talk
