>Correct, if you create some makeArchiveConfigFile("/path/to/config.xml")
tool for the >IOC, you could use the info field support code in EPICS
base to get the information, >invoke it in st.cmd, so after each IOC
reboot you'd have an archive config file for the
>IOC.
Cool, I guess if we restrict to only generating the .req file, this way the solution will be quite nifty. Adding the xml generation library to it will make it bulky. I suggest a two stage solution, the makeArchiveConfigFile will make a .req file. Each line of this .req file will contain all the necessary archive information per PV. This file can subsequently be parsed using a python app for generating a CSS archive compatible xml config file.
We can extend the AutosaveFileFromDbInfo function and request the maintainer if this can be a standard feature of autosave.
It will help if you can suggest names and the parameters that we may require from the info field.
Regards, Kuldeep
> I wonder if leveraging the function makeAutosaveFileFromDbInfo from the autosave module is used, one may not have to worry about macro substitution.
Correct, if you create some makeArchiveConfigFile("/path/to/config.xml") tool for the IOC, you could use the info field support code in EPICS base to get the information, invoke it in st.cmd, so after each IOC reboot you'd have an archive config file for the
IOC.
At the time we were looking for a tool that runs on the host, at the time you "make" the IOC software. But you can't archive anything unless the IOC is running,
so requiring the IOC to start first is actually somewhat logical.
-Kay
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Ralph Lange via Tech-talk
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kasemir, Kay via Tech-talk
- Phoebus Archive xml config file: Automate generation. Kuldeep Joshi via Tech-talk
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation. Kasemir, Kay via Tech-talk
- Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Re: Stream device: Reading values from two almost identical input strings using I/O intr Ralph Lange via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
