> I guess if we restrict to only generating the .req file, this way the solution will be quite nifty. Adding the xml generation library to it will make it bulky.
> I suggest a two stage solution, the makeArchiveConfigFile will make a .req file. Each line of this .req file will contain all the necessary archive information per PV. This file can subsequently be parsed using a python app for generating a CSS archive compatible xml config file.
> We can extend the AutosaveFileFromDbInfo function and request the maintainer if this can be a standard feature of autosave.
The information that you need is
1) How to sample: scan or monitor
2) How often to do that, i.e. scan period or estimated update period
3) PV name, which usually is the record name with implied .VAL, but in rare cases you might for example want the .RBV
Example:
# Request archiving on change
info(archive, "Monitor, 00:01:00")
# Scan
info(archive, "Scan, 01:00:00")
# VAL field is the default
info(archive, "Monitor, 00:01:00, VAL")
# In rare cases, might need to archive other fields
info(archive, "Monitor, 00:01:00, RVAL DMOV")
Why do you want to add this to the autosave/restore code? They're not related.
Why do you want to create some arbitrary intermediate file format?
Why not create the XML right away?
Yes, I would avoid adding an XML library, but "printf" will suffice since you know what you'll write. Just check the PV names for a very limited number of potential characters to escape, which I think is basically '>' and '<'.
So something like ` makeArchiveConfigFile("/path/to/ioc_xyz_archive.xml")` at the end of st.cmd will create one file per IOC, and you can then use xinclude to merge the per-IOC files into one per archive engine.
-Kay
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Michael Davidsaver via Tech-talk
- Phoebus Archive xml config file: Automate generation. Kuldeep Joshi via Tech-talk
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation. Kasemir, Kay via Tech-talk
- Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kasemir, Kay via Tech-talk
- Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Ralph Lange via Tech-talk
Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
