We would like to rotate an image using area detector by an arbitrary angle, much like the python function imutils.rotate_bound which rotates an image and doesn’t cut off the corners. Ultimately we are trying to get statistics of an ellipse
which is not aligned on x and y.
Has anybody extended the AreaDetector NDTransform plugin, or written another one to do anything like this? What are other people’s approaches?
Thanks
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
- Re: Arbitrary rotation angle with areaDetector Plugin Michael Davidsaver via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Michael Davidsaver via Tech-talk
<2021>
2025
2026
Re: Stream device: Reading values from two almost identical input strings using I/O intr Zimoch Dirk (PSI) via Tech-talk
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
