Subject: Re: Arbitrary rotation angle with areaDetector Plugin
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Smith, William" <[email protected]>
Cc: "[email protected]" <[email protected]>, "Kazarski, Sebastian" <[email protected]>
Date: Thu, 29 Jul 2021 08:10:16 -0700
On 7/29/21 7:22 AM, Smith, William via Tech-talk wrote:
> Hi,
> We would like to rotate an image using area detector by an arbitrary angle, much like the python function imutils.rotate_bound which rotates an image and doesn’t cut off the corners. Ultimately we are trying to get statistics of an ellipse which is not aligned on x and y.
> Has anybody extended the AreaDetector NDTransform plugin, or written another one to do anything like this? What are other people’s approaches?
It may well be stale at this point, but my NDWarp plugin can do this.
https://github.com/mdavidsaver/ndwarp/blob/2eb73105dd886c9dc89e96b3d77661b9bf770a02/warpApp/Db/NDWarp.template#L40
Rotation being one case of the possible coordinate transformations.
The name "warp" coming from skimage, which I used for prototyping.
https://scikit-image.org/docs/dev/api/skimage.transform.html#skimage.transform.warp
RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Michael Davidsaver via Tech-talk
Next: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Prev: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Next: RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
