Subject: int64in record not sending monitors for larger value changes
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Thu, 29 Jul 2021 15:29:25 +0000
Hi:
I'm trying to use the relatively new 64 bit records in EPICS base.
I understand that Channel Access doesn't fully support them, the 64 bit integer is transferred as a double, so small changes in large numbers get truncated. I'm not sure if that fully explains the observed behavior, though.
Example record, executed with `softIocPVA`:
record(int64in, "sixtyfour")
   field(PINI, "YES")
Writing a few values within bash, using its support for converting hex to decimal:
caput sixtyfour $(( 16#FF ))
Old : sixtyfour                      0
New : sixtyfour                      255
caput sixtyfour $(( 16#87654321 ))
Old : sixtyfour                      255
New : sixtyfour                      2.27156e+09
caput sixtyfour $(( 16#32187654321 ))
Old : sixtyfour                      2.27156e+09
New : sixtyfour                      3.44254e+12
Note how the "New :" read-back of the written value looks OK.
The output of 'camonitor sixtyfour', however, stops updating as the value grows beyond 0x87654321:
sixtyfour                      2021-07-29 10:59:04.516933 0
sixtyfour                      2021-07-29 10:59:32.500969 255
sixtyfour                      2021-07-29 10:59:39.130877 2.27156e+09
Same with the output of 'pvmonitor sixtyfour', just slightly different formatting:
sixtyfour 2021-07-29 10:59:04.517  0
sixtyfour 2021-07-29 10:59:32.501  255
sixtyfour 2021-07-29 10:59:39.131  2271560481
If I stop & restart the monitors, they see the correct value:
camonitor sixtyfour
sixtyfour                      2021-07-29 11:00:07.627927 3.44254e+12
pvmonitor sixtyfour
sixtyfour 2021-07-29 11:00:07.628  3442540364577
.. but again they're stuck there when I 'caput $(( 16#87654321 ))', the smaller value.
I don't think it's a rounding/truncation error from the conversion to double, because floating point 2.27156e+09 !=  3.44254e+12
This is with R7.0.4.1.
Kay
Re: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Prev: Re: Arbitrary rotation angle with areaDetector Plugin Michael Davidsaver via Tech-talk
Next: Re: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Prev: RE: Arbitrary rotation angle with areaDetector Plugin Mark Rivers via Tech-talk
