> I'm trying to use the relatively new 64 bit records in EPICS base..
> The output of 'camonitor sixtyfour', however, stops updating as the value grows beyond 0x87654321:
The reason is this section in int64inRecord.c:
/* DELTA calculates the absolute difference between its arguments
* expressed as an unsigned 32-bit integer */
#define DELTA(last, val) \
((epicsUInt32) ((last) > (val) ? (last) - (val) : (val) - (last)))
It only checks for changes in the lower 32 bits of the value.
Maybe the motivation was to always perform an _unsigned_ comparison, but "UInt32" was copy/pasted instead of "UInt64"?
-Kay
- Re: int64in record not sending monitors for larger value changes Johnson, Andrew N. via Tech-talk
- int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
