Subject: Re: int64in record not sending monitors for larger value changes
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Kay Kasemir <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 29 Jul 2021 15:48:14 +0000
Hello Kay,
On Jul 29, 2021, at 10:37 AM, Kasemir, Kay via Tech-talk <[email protected]> wrote:
I'm trying to use the relatively new 64 bit records in EPICS base..
The output of 'camonitor sixtyfour', however, stops updating as the value grows beyond 0x87654321:
The reason is this section in int64inRecord.c:
/* DELTA calculates the absolute difference between its arguments
 * expressed as an unsigned 32-bit integer */
#define DELTA(last, val) \
    ((epicsUInt32) ((last) > (val) ? (last) - (val) : (val) - (last)))
It only checks for changes in the lower 32 bits of the value.
Maybe the motivation was to always perform an _unsigned_ comparison, but "UInt32" was copy/pasted instead of "UInt64"?
The int64{in,out} record types were created from the long{in,out} types, and it looks like it that particular 32 to 64 conversion was just missed.
Would you mind creating an issue or even a pull request in GitHub for the appropriate change, just so we don’t forget about it?
Thanks!
- Andrew
Complexity comes for free, simplicity you have to work for.
int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Re: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Prev: Re: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
Next: RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Next: StreamDevice protocol file question Wang, Andrew via Tech-talk
