Subject: RE: Arbitrary rotation angle with areaDetector Plugin
To: "'Smith, William'" <[email protected]>, Michael Davidsaver <[email protected]>
Cc: "[email protected]" <[email protected]>, "Kazarski, Sebastian" <[email protected]>
Date: Thu, 29 Jul 2021 22:20:17 +0000
Hi Will,
> I know what you mean generally, I understand how to include support modules in other applications or support modules, but I don't know how to do it with areaDetector.
> Where are the other NDPlugins defined?
Most plugins are in ADCore.
> Can I just copy the source code and database from Michael's NDWarp into some location in areaDetector core and rebuild?
You could do that.  But I would suggest you put NDWarp in a separate directory under areaDetector.  Then add this line to areaDetector/configure/RELEASE_PRODS.local
NDWARP=$(AREA_DETECTOR)/NDWarp
and add these lines to areaDetector/ADCore/ADApp/commonDriverMakefile
ifdef NDWARP
  $(DBD_NAME)_DBD += NDPluginWarp.dbd
  PROD_LIBS       += NDPluginWarp
endif
-----Original Message-----
Sent: Thursday, July 29, 2021 2:47 PM
To: Mark Rivers <[email protected]>; Michael Davidsaver <[email protected]>
Cc: Kazarski, Sebastian <[email protected]>; [email protected]
Hi Mark,
I am not sure I understand exactly. I know what you mean generally, I understand how to include support modules in other applications or support modules, but I don't know how to do it with areaDetector. Where are the other NDPlugins defined? Can I just copy the source code and database from Michael's NDWarp into some location in areaDetector core and rebuild?
Thanks
Will
Sent: Thursday, July 29, 2021 8:56 PM
To: Smith, William <[email protected]>; Michael Davidsaver <[email protected]>
> This looks perfect. How do I include a new ND plugin in an existing area Detector installation?
You need to recompile your areaDetector application to include this new plugin.  You need to add it to the application dbd file and include the library in your application Makefile.
From: Tech-talk <[email protected]> On Behalf Of Smith, William via Tech-talk
Sent: Thursday, July 29, 2021 11:01 AM
To: Michael Davidsaver <[email protected]>
Cc: [email protected]; Kazarski, Sebastian <[email protected]>
Hi Michael,
Will
Sent: Thursday, July 29, 2021 5:10 PM
Subject: Re: Arbitrary rotation angle with areaDetector Plugin
On 7/29/21 7:22 AM, Smith, William via Tech-talk wrote:
> Hi,
> We would like to rotate an image using area detector by an arbitrary angle, much like the python function imutils.rotate_bound which rotates an image and doesn’t cut off the corners. Ultimately we are trying to get statistics of an ellipse which is not aligned on x and y.
> Has anybody extended the AreaDetector NDTransform plugin, or written another one to do anything like this? What are other people’s approaches?
It may well be stale at this point, but my NDWarp plugin can do this.
https://github.com/mdavidsaver/ndwarp/blob/2eb73105dd886c9dc89e96b3d77661b9bf770a02/warpApp/Db/NDWarp.template#L40
Rotation being one case of the possible coordinate transformations.
The name "warp" coming from skimage, which I used for prototyping.
https://scikit-image.org/docs/dev/api/skimage.transform.html#skimage.transform.warp
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Re: Arbitrary rotation angle with areaDetector Plugin Michael Davidsaver via Tech-talk
RE: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
RE: Arbitrary rotation angle with areaDetector Plugin Mark Rivers via Tech-talk
Prev: Re: Arbitrary rotation angle with areaDetector Plugin Wlodek, Jakub via Tech-talk
Next: StreamDevice protocol file question Wang, Andrew via Tech-talk
Next: int64in record not sending monitors for larger value changes Kasemir, Kay via Tech-talk
