Subject: Re: Autostart with manage-procs and network mounts
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Smith, William" <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Aug 2021 10:16:52 -0700
On 8/3/21 3:07 AM, Smith, William via Tech-talk wrote:
> Hi,
> I am using manage-procs to deploy and manage IOC’s using systemd. It creates the systemd files that look something like what is shown below. I mount a network drive over nfs at boot that contains the built IOC binaries for the service to run. The service is enabled, it should start at boot but it doesn’t because the ConditionPathIsDirectory fails. If I go to the directory after the system has booted, I can see that it has been mounted correctly and exists. I cc Wayne because I seem to remember us having a similar problem at ESS about 2 years ago but I can’t remember how we solved it! Does anybody have any ideas?
How is the relevant NFS share being mounted?  Via /etc/fstab, autofs,
or some other initiator?
I think that "After=network.target remote-fs.target" should be enough
to ensure ordering.  You could try adding
"Requires=network.target remote-fs.target".
> Many thanks,
> Will
> emil@sissy-ioc-01:/etc/systemd/system$ cat procserv-EMIL_KTH_00.service
> [Unit]
> Description=procServ for EMIL_KTH_00
> ConditionPathIsDirectory=/home/emil/Apps/epics/R7.0.4.1/prod/ioc/EMILEL/EMIL_KTH_00/1-4-0/iocBoot/iocEMIL_KTH_00
> [Service]
> Type=simple
> ExecStart=/usr/local/bin/procServ-launcher --system EMIL_KTH_00
> RuntimeDirectory=procserv-EMIL_KTH_00
> StandardOutput=syslog
> StandardError=inherit
> SyslogIdentifier=procserv-EMIL_KTH_00
> User=emil
> Group=emil
> [Install]
> WantedBy=multi-user.target
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> 14109 Berlin
> Deutschland
Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Kasemir, Kay via Tech-talk
RE: Autostart with manage-procs and network mounts Smith, William via Tech-talk
Prev: RE: Getting started with EPICS lecture videos Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Kasemir, Kay via Tech-talk
Prev: Autostart with manage-procs and network mounts Smith, William via Tech-talk
