Subject: RE: Autostart with manage-procs and network mounts
From: "Smith, William via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 4 Aug 2021 09:25:16 +0000
Hi Michael,
I am using /etc/fstab
I solved the problem for my case by adding: "name-of-mount.mount" in the end of the After line like this:
After=network.target remote-fs.target name-of-mount.mount
I found the name-of-mount using
> systemctl list-units --type=mount
I used this for help: https://unix.stackexchange.com/a/247547
Obviously this doesn’t work in a general case, only for my deployment system. For now I have edited the generator.py file of manage-procs.  I haven't looked at used autofs before.
I will follow the github issue you've made and post anything else there if I think of anything.
Best
Will
-----Original Message-----
Sent: Tuesday, August 3, 2021 7:17 PM
To: Smith, William <[email protected]>
Cc: [email protected]; [email protected]
Subject: Re: Autostart with manage-procs and network mounts
On 8/3/21 3:07 AM, Smith, William via Tech-talk wrote:
> Hi,
> I am using manage-procs to deploy and manage IOC’s using systemd. It creates the systemd files that look something like what is shown below. I mount a network drive over nfs at boot that contains the built IOC binaries for the service to run. The service is enabled, it should start at boot but it doesn’t because the ConditionPathIsDirectory fails. If I go to the directory after the system has booted, I can see that it has been mounted correctly and exists. I cc Wayne because I seem to remember us having a similar problem at ESS about 2 years ago but I can’t remember how we solved it! Does anybody have any ideas?
How is the relevant NFS share being mounted?  Via /etc/fstab, autofs, or some other initiator?
I think that "After=network.target remote-fs.target" should be enough to ensure ordering.  You could try adding "Requires=network.target remote-fs.target".
> Many thanks,
> Will
> emil@sissy-ioc-01:/etc/systemd/system$ cat
> procserv-EMIL_KTH_00.service
> [Unit]
> Description=procServ for EMIL_KTH_00
> ConditionPathIsDirectory=/home/emil/Apps/epics/R7.0.4.1/prod/ioc/EMILE
> L/EMIL_KTH_00/1-4-0/iocBoot/iocEMIL_KTH_00
> [Service]
> Type=simple
> ExecStart=/usr/local/bin/procServ-launcher --system EMIL_KTH_00
> RuntimeDirectory=procserv-EMIL_KTH_00
> StandardOutput=syslog
> StandardError=inherit
> SyslogIdentifier=procserv-EMIL_KTH_00
> User=emil
> Group=emil
> [Install]
> WantedBy=multi-user.target
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr.
> Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd
> Rech, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> 14109 Berlin
> Deutschland
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
14109 Berlin
Deutschland
Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Autostart with manage-procs and network mounts Smith, William via Tech-talk
Prev: Great Opportunity for Particle Accelerator Instrumentation Physicist/Engineer Nicholas James Meyler via Tech-talk
Next: db/streamdevice/proto Agilent 34970A Heinz Junkes via Tech-talk
Prev: Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Ernesto Paiser via Tech-talk
Next: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
