On 8/3/21 10:22 AM, Kasemir, Kay wrote:
>> > I am using manage-procs to deploy and manage IOC’s using systemd. ..network drive over nfs at boot that contains the built IOC binaries
>> I think that "After=network.target remote-fs.target" should be enough to ensure ordering. You could try adding
>> "Requires=network.target remote-fs.target".
> I think we had similar issues with network mounts not being up in time for the IOCs to start when we had just this in the IOC systemd files:
> Requires=autofs.service
> The following belt-and-suspenders approach fixed the problem, though I'm not sure exactly why:
I would be reluctant to blindly add this as I think it would make manage-procs
unusable by default for installations w/o autofs. If a Requires= turns out to
be necessary, manage-procs would probably have to detect this somehow.
This is actually redundant to "BindsTo=autofs.service".
> After=autofs.service
This seems reasonable, and would hopefully be sufficient by itself.
> Wants=autofs.service
This should probably be ok, but would need some testing. I would expect that
if autofs is installed, that it is installed and should be running.
cf. https://www.freedesktop.org/software/systemd/man/systemd.unit.html#Wants=
- Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Ernesto Paiser via Tech-talk
- Autostart with manage-procs and network mounts Smith, William via Tech-talk
- Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
- Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Kasemir, Kay via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
