Subject: Re: Lib directory is not created for RTEMS (EPICS 7).
From: Michael Davidsaver via Tech-talk <[email protected]>
To: cristian ramos <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 4 Aug 2021 08:32:14 -0700
On 8/4/21 7:49 AM, cristian ramos via Tech-talk wrote:
> Hello,
>      I am writing to see if you can give me some guidance on the following error I am having. I am trying to migrate a module from EPICS 3.15.8 to EPCIS 7. The module compiles correctly, except that when I invoke the make command for RTEMS the lib directory is not created automatically. If I change the macro in the Makefile to compile for the other platforms, in this case, linux_x86_64 the lib directory is created when the make command is invoked. Basically, by declaring the macro LIBRARY_IOC_RTEMS += <module_name_lib>, the lib directory is not created when invoking make, whereas if you change the macro to
> LIBRARY_IOC += <module_name_lib> the lib directory is created.
>     To provide more information, with the previous version (EPICS 3.15.8) it behaves as expected but with EPICS 7, this is not the case. Maybe I need to take something into account with the new version of EPICS to have the same effect as with the previous version.
Which RTEMS version and target(s) are you using?
Lib directory is not created for RTEMS (EPICS 7). cristian ramos via Tech-talk
Prev: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Next: Re: Lib directory is not created for RTEMS (EPICS 7). Johnson, Andrew N. via Tech-talk
Prev: Lib directory is not created for RTEMS (EPICS 7). cristian ramos via Tech-talk
