Subject: Lib directory is not created for RTEMS (EPICS 7).
From: cristian ramos via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 4 Aug 2021 10:49:07 -0400
Hello,
     I am writing to see if you can give me some guidance on the following error I am having. I am trying to migrate a module from EPICS 3.15.8 to EPCIS 7. The module compiles correctly, except that when I invoke the make command for RTEMS the lib directory is not created automatically. If I change the macro in the Makefile to compile for the other platforms, in this case, linux_x86_64 the lib directory is created when the make command is invoked. Basically, by declaring the macro LIBRARY_IOC_RTEMS += <module_name_lib>, the lib directory is not created when invoking make, whereas if you change the macro to
LIBRARY_IOC += <module_name_lib> the lib directory is created.
    To provide more information, with the previous version (EPICS 3.15.8) it behaves as expected but with EPICS 7, this is not the case. Maybe I need to take something into account with the new version of EPICS to have the same effect as with the previous version.
    Thank you very much in advance.
Re: Lib directory is not created for RTEMS (EPICS 7). Michael Davidsaver via Tech-talk
Re: Lib directory is not created for RTEMS (EPICS 7). Johnson, Andrew N. via Tech-talk
Prev: db/streamdevice/proto Agilent 34970A Heinz Junkes via Tech-talk
Next: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Prev: Re: db/streamdevice/proto Agilent 34970A Dunning, Michael via Tech-talk
Next: Re: Lib directory is not created for RTEMS (EPICS 7). Michael Davidsaver via Tech-talk
