Yes, there are other support modules:
Calc, Tbuf (time buffer for pico8), PyDevSup, SScan, autosave, iocstats, and caputlog.
If I set the IOC back to 1 thread with all four cards, the shell is spammed with output:
DIAG_MTCA17:PICO8_CH0:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH1:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH2:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH3:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH4:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH5:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH6:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH7:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH0:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH1:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH2:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH3:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH4:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH5:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH6:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH7:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
I assume this is because there is some bottleneck. If I reduce to 1 thread and 1 hardware device, the output is gone. So, with the following in mind:
-1 thread is too slow for four devices
-multiple threads is untested
Is the best workaround to split these into multiple IOCs? That way, I assume, there is parallel processing without untested resource contention.
-----Original Message-----
Sent: Thursday, August 5, 2021 11:41 AM
To: Johnson, Andrew N. <[email protected]>; Daykin, Evan <[email protected]>
Cc: EPICS tech-talk <[email protected]>; Rivers, Mark L. <[email protected]>
Subject: Re: cbLow consumption randomly stopping
[EXTERNAL] This email originated from outside of FRIB
On 8/5/21 8:30 AM, Johnson, Andrew N. wrote:
> Hi Evan,
> Does this IOC load /any/ other EPICS drivers or device support at all (other than the standard ones that come with Base)?
> Your configuration with multiple callback threads is unusual, and a lot of device/driver support might not have been written or tested with the thought that there could more than one such callback in mind, so any such support code might be contributing to this issue.
I'll second this. I never tested the pico8 driver (or any of my
drivers) with parallel callbacks enabled.
- Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
- cbLow consumption randomly stopping Daykin, Evan via Tech-talk
- Re: cbLow consumption randomly stopping Mark Rivers via Tech-talk
- RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
- Re: cbLow consumption randomly stopping Johnson, Andrew N. via Tech-talk
Re: How to find out PVs preventing SSCAN from running? Li, Ji via Tech-talk
Re: How to find out PVs preventing SSCAN from running? Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
