Subject: RE: cbLow consumption randomly stopping
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>, "Johnson, Andrew N." <[email protected]>
Date: Wed, 4 Aug 2021 19:33:46 +0000
Hello again,
Just reviving this thread as I was able to do some more digging, but still no solution. Some more data points:
The PICO module is not stopping. debugPICO PICO<n> 5 spams output like always.
In bugged state, cbLow threads are stopped in FUTEX_WAIT_PRIVATE  for some reason, but I'm having trouble figuring out why. If I run strace -fp <pid> and search for the LWP ID's associated with cbLow-1...cbLow-8, I get exactly one hit for each cbLow thread:
1669 futex(0x55a511f78924, FUTEX_WAIT_PRIVATE, 0, NULL <unfinished ...>
OTOH, during normal operation, I see what I'd expect:
21864 futex(0x55cc299855f0, FUTEX_WAIT_PRIVATE, 0, NULL <unfinished ...>
21864 <... futex resumed> )
21864 futex(0x55cc299855f0, FUTEX_WAKE_PRIVATE, 1 <unfinished ...>
Andrew, I saw you'd mentioned it could be in the callback subsystem. Should I file a bug report in base? If so, is there any other info you'd like me to add before submitting?
Have a nice day,
Evan
-----Original Message-----
Sent: Tuesday, June 15, 2021 5:30 PM
To: Michael Davidsaver <[email protected]>; Mark Rivers <[email protected]>
Cc: [email protected]
The issue just happened again on another device. So as promised, here is the github mirror:
https://github.com/frib-bim/caen-blm-software
And some more debug information - epicsMutexShowAll 1, info threads, thread apply all bt:
https://gist.github.com/daykin/6ab54c10e46d119785a89f3cf88d424c
Cheers,
Evan
Sent: Tuesday, June 8, 2021 3:31 PM
To: Daykin, Evan <[email protected]>; Mark Rivers <[email protected]>
Subject: Re: cbLow consumption randomly stopping
[EXTERNAL] This email originated from outside of FRIB
On 6/8/21 12:19 PM, Daykin, Evan wrote:
>> , if you think there is a deadlock, I would suggest attaching GDB to a running  IOC process and capture all the stack.
> So should I run `bt full` on the cbLow thread?
I should have written "... all of the stacks".  So all threads, or "thread apply all backtrace".
> From: Michael Davidsaver <[email protected]>
> Sent: Tuesday, June 8, 2021 2:20 PM
> On 6/8/21 11:03 AM, Daykin, Evan via Tech-talk wrote:
>>> Is the driver or device support using asyn? If so, what version?
>> No, it seems to be using epicspci/devlib2 to communicate with hardware.
> I think this driver was one that I did back in 2017.
> @Andrew, Mark hardware access is partly through a Linux driver [1], and partly
> through MMIO for a custom register range.  The Linux driver is public, but the
> EPICS driver was FRIB internal.  (it would be nice if this could be public as well)
> @Evan, if you think there is a deadlock, I would suggest attaching GDB to a running
> Looking back, I also added a per-device logging mask (a la asyn).  cf. "debugPico()"
> at the IOC shell.
>> All cbLow threads show same backtrace.
> These threads are expected to be in epicsEventWait() when idling.
> So this by itself does not indicate a deadlock.
> [1] https://github.com/CAENels/amc-pico8-driver and/or https://github.com/mdavidsaver/amc-pico8-driver
>> @Andrew, here is some output from attaching gdb:
>> (gdb) info threads
>>   Id   Target Id                                           Frame
>>   1    Thread 0x7fd5a60a5c80 (LWP 22198) "st.cmd"          0x00007fd5a9d62151 in __pselect (nfds=1, readfds=0x7fff0eb98db0, writefds=0x0, exceptfds=0x0, timeout=<optimized out>, sigmask=<optimized out>) at ../sysdeps/unix/sysv/linux/pselect.c:69
>>   2    Thread 0x7fd5a5899700 (LWP 22200) "errlog"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d2538054) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   3    Thread 0x7fd5a5818700 (LWP 22202) "Reader"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d2612600) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   4    Thread 0x7fd5a5797700 (LWP 22203) "capture"         __GI___libc_read (nbytes=176, buf=0x7fd598000b20, fd=9) at ../sysdeps/unix/sysv/linux/read.c:26
>>   5    Thread 0x7fd5a5716700 (LWP 22204) "Reader"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d26144d0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   6    Thread 0x7fd5a5695700 (LWP 22205) "capture"         __GI___libc_read (nbytes=176, buf=0x7fd59c000b20, fd=13) at ../sysdeps/unix/sysv/linux/read.c:26
>>   7    Thread 0x7fd5a5614700 (LWP 22206) "Reader"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d26163c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   8    Thread 0x7fd5a5593700 (LWP 22207) "capture"         __GI___libc_read (nbytes=176, buf=0x7fd590000b20, fd=17) at ../sysdeps/unix/sysv/linux/read.c:26
>>   9    Thread 0x7fd5a5512700 (LWP 22208) "Reader"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d2618350) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   10   Thread 0x7fd5a5491700 (LWP 22209) "capture"         __GI___libc_read (nbytes=176, buf=0x7fd594000b20, fd=21) at ../sysdeps/unix/sysv/linux/read.c:26
>>   11   Thread 0x7fd5a5410700 (LWP 22217) "taskwd"          futex_abstimed_wait_cancelable (private=0, abstime=0x7fd5a540fcf0, expected=0, futex_word=0x55c1d2e56e00) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   12   Thread 0x7fd5a538f700 (LWP 22218) "timerQueue"      futex_abstimed_wait_cancelable (private=0, abstime=0x7fd5a538ecc0, expected=0, futex_word=0x55c1d2619b74) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>> * 13   Thread 0x7fd5a609a700 (LWP 22219) "cbLow-0"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   14   Thread 0x7fd5a528e700 (LWP 22220) "cbLow-1"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   15   Thread 0x7fd5a508d700 (LWP 22221) "cbLow-2"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   16   Thread 0x7fd5a4e8c700 (LWP 22222) "cbLow-3"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   17   Thread 0x7fd5a4c8b700 (LWP 22223) "cbLow-4"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   18   Thread 0x7fd5a4a8a700 (LWP 22224) "cbLow-5"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   19   Thread 0x7fd5a4889700 (LWP 22225) "cbLow-6"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   20   Thread 0x7fd5a4688700 (LWP 22226) "cbLow-7"         futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   21   Thread 0x7fd5a4487700 (LWP 22227) "cbMedium"        futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d31ed8c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   22   Thread 0x7fd5a4286700 (LWP 22228) "cbHigh"          futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d31edac0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   23   Thread 0x7fd567fff700 (LWP 22229) "dbCaLink"        futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d31edeb4) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   24   Thread 0x7fd567dfe700 (LWP 22230) "timerQueue"      futex_abstimed_wait_cancelable (private=0, abstime=0x7fd567dfdcc0, expected=0, futex_word=0x55c1d31eef44) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   25   Thread 0x7fd55095c700 (LWP 22233) "scanOnce"        futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d3883b80) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   26   Thread 0x7fd55075b700 (LWP 22234) "scan-10"         futex_abstimed_wait_cancelable (private=0, abstime=0x7fd55075acd0, expected=0, futex_word=0x55c1d3883360) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   27   Thread 0x7fd55055a700 (LWP 22235) "scan-5"          futex_abstimed_wait_cancelable (private=0, abstime=0x7fd550559cd0, expected=0, futex_word=0x55c1d38834a0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   28   Thread 0x7fd550359700 (LWP 22236) "scan-2"          futex_abstimed_wait_cancelable (private=0, abstime=0x7fd550358cd0, expected=0, futex_word=0x55c1d38835e0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   29   Thread 0x7fd543fff700 (LWP 22237) "scan-1"          futex_abstimed_wait_cancelable (private=0, abstime=0x7fd543ffecd0, expected=0, futex_word=0x55c1d3883720) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   30   Thread 0x7fd543dfe700 (LWP 22238) "scan-0.5"        futex_abstimed_wait_cancelable (private=0, abstime=0x7fd543dfdcd0, expected=0, futex_word=0x55c1d3883860) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   31   Thread 0x7fd543bfd700 (LWP 22239) "scan-0.2"        futex_abstimed_wait_cancelable (private=0, abstime=0x7fd543bfccd0, expected=0, futex_word=0x55c1d38839a0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   32   Thread 0x7fd5439fc700 (LWP 22240) "scan-0.1"        futex_abstimed_wait_cancelable (private=0, abstime=0x7fd5439fbcd0, expected=0, futex_word=0x55c1d3883ae0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   33   Thread 0x7fd5437fb700 (LWP 22241) "asCaTask"        futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d3927c70) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   34   Thread 0x7fd5435fa700 (LWP 22242) "ipToAsciiProxy"  futex_wait_cancelable (private=0, expected=0, futex_word=0x7fd52c00fa34) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   35   Thread 0x7fd56418c700 (LWP 22243) "timerQueue"      futex_abstimed_wait_cancelable (private=0, abstime=0x7fd56418bcc0, expected=0, futex_word=0x7fd52c010224) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   36   Thread 0x7fd550158700 (LWP 22244) "CAC-UDP"         0x00007fd5a9d6b742 in __libc_recvfrom (fd=26, buf=0x7fd52c0127d8, len=65551, flags=0, addr=..., addrlen=0x7fd550157ca8) at ../sysdeps/unix/sysv/linux/recvfrom.c:27
>>   37   Thread 0x7fd5433f9700 (LWP 22245) "CAC-TCP-recv"    __libc_recv (flags=0, len=16384, buf=0x7fd54307b04c, fd=28) at ../sysdeps/unix/sysv/linux/recv.c:28
>>   38   Thread 0x7fd5431f8700 (LWP 22246) "CAC-TCP-send"    futex_wait_cancelable (private=0, expected=0, futex_word=0x7fd52000e830) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   39   Thread 0x7fd543076700 (LWP 22256) "CAS-TCP"         0x00007fd5a9d6b437 in __libc_accept (fd=29, addr=..., len=0x7fd543075cec) at ../sysdeps/unix/sysv/linux/accept.c:26
>>   40   Thread 0x7fd542f75700 (LWP 22257) "CAS-UDP"         0x00007fd5a9d6b742 in __libc_recvfrom (fd=30, buf=0x7fd50c001a50, len=65551, flags=0, addr=..., addrlen=0x7fd542f74ce8) at ../sysdeps/unix/sysv/linux/recvfrom.c:27
>>   41   Thread 0x7fd542e74700 (LWP 22258) "CAS-beacon"      0x00007fd5a9d37720 in __GI___nanosleep (requested_time=0x7fd542e73c50, remaining=0x7fd542e73c60) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
>>   42   Thread 0x7fd542df3700 (LWP 22259) "CAC-event"       futex_wait_cancelable (private=0, expected=0, futex_word=0x7fd56008ccd0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   43   Thread 0x7fd542cf2700 (LWP 22260) "logRestart"      futex_abstimed_wait_cancelable (private=0, abstime=0x7fd542cf1d30, expected=0, futex_word=0x55c1d39310d0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   44   Thread 0x7fd542c71700 (LWP 22261) "caPutLog"        futex_wait_cancelable (private=0, expected=0, futex_word=0x7fd4f8000b90) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   45   Thread 0x7fd542bf0700 (LWP 22262) "logRestart"      futex_abstimed_wait_cancelable (private=0, abstime=0x7fd542befd30, expected=0, futex_word=0x55c1d393f270) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   46   Thread 0x7fd542b6f700 (LWP 22263) "save_restore"    futex_abstimed_wait_cancelable (private=0, abstime=0x7fd542b6e880, expected=0, futex_word=0x7fd4fc0204e0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
>>   47   Thread 0x7fd54296e700 (LWP 22264) "reccaster-etcd"  0x00007fd5a9d37720 in __GI___nanosleep (requested_time=0x7fd54296dc40, remaining=0x7fd54296dc50) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
>>   48   Thread 0x7fd5428ed700 (LWP 22265) "recEtcdConsumer" futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d61a30d0) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   49   Thread 0x7fd54286c700 (LWP 22266) "recEtcdConsumer" futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d61a3380) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>>   50   Thread 0x7fd5427eb700 (LWP 22267) "recEtcdConsumer" futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d61a3630) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>> (gdb) thread 13
>> [Switching to thread 13 (Thread 0x7fd5a609a700 (LWP 22219))]
>> #0  futex_wait_cancelable (private=0, expected=0, futex_word=0x55c1d321ba40) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
>> 88	../sysdeps/unix/sysv/linux/futex-internal.h: No such file or directory.
>> (gdb) bt
>> #1  __pthread_cond_wait_common (abstime=0x0, mutex=0x55c1d321b9f0, cond=0x55c1d321ba18) at pthread_cond_wait.c:502
>> #2  __pthread_cond_wait (cond=0x55c1d321ba18, mutex=0x55c1d321b9f0) at pthread_cond_wait.c:655
>> #3  0x00007fd5a9f3051b in epicsEventWait () from /lib/x86_64-linux-gnu/libCom.so.3.15.8
>> #4  0x00007fd5a9f28c99 in epicsEventMustWait () from /lib/x86_64-linux-gnu/libCom.so.3.15.8
>> #5  0x00007fd5a9f9c251 in ?? () from /lib/x86_64-linux-gnu/libdbCore.so.3.15.8
>> #6  0x00007fd5a9f2da7b in ?? () from /lib/x86_64-linux-gnu/libCom.so.3.15.8
>> #7  0x00007fd5a98e9fa3 in start_thread (arg=<optimized out>) at pthread_create.c:486
>> #8  0x00007fd5a9d6a4cf in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
>> Thanks for the help,
>> Evan
>> From: Mark Rivers <[email protected]>
>> Sent: Tuesday, June 8, 2021 1:27 PM
>> [EXTERNAL] This email originated from outside of FRIB One possibility is that the thread the pulls the message out of the queue has locked up for some reason.One possibility is a deadlock.  When this happens you could try typingepicsMutexShowAll 1several times.  If the same mutexes are locked each time you type that, then there is likely a deadlock.What OS is this?What version of EPICS base?Is the driver or device support using asyn?  If so, what version?Mark________________________________From: Tech-talk <[email protected]> on behalf of Daykin, Evan via Tech-talk <[email protected]>Sent: Tuesday, June 8, 2021 12:10 PMTo: EPICS tech-talkSubject: cbLow consumption randomly stoppingHello tech-talk,We have an IOC repeatedly locking up with the infamous "cbLow ring buffer full" message. The IOC consumes data from our CAEN Pico-8 card via an EPICS driver at 100Hz (about 1200-1215 events per second total) , and at some point on the order of hours to days, seems to stop consuming callbacks from the queue. I wrote a script to track this, and it seems to all be happening in one shot. Below is some data I captured from the last time this happened. Before this, everything was happy for about 4 hours, but sometimes it takes up to a week for this to happen.TimeHigh-waterItems in qQ capacity%Oflws6/7/2021 19:22:4013012000006/7/2021 19:22:4113012000006/7/2021 19:22:4213012000006/7/2021 19:22:4413012000006/7/2021 19:22:45571571120004.806/7/2021 19:22:46177817781200014.806/7/2021 19:22:47299129911200024.906/7/2021 19:22:4842044204120003506/7/2021 19:22:4954065406120004506/7/2021 19:22:50661966191200055.206/7/2021 19:22:51783478341200065.306/7/2021 19:22:52904890481200075.406/7/2021 19:22:5310249102491200085.406/7/2021 19:22:5411462114621200095.506/7/2021 19:22:5612000120001200010016/7/2021 19:22:581200012000120001001Has anyone else experienced this? If so, what is the remedy? I can't seem to correlate it to anything unusual happening in the OS/kernel.Thanks,Evan
Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Re: cbLow consumption randomly stopping Mark Rivers via Tech-talk
RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Prev: Re: Archive appliance on RHEL8 Shankar, Murali via Tech-talk
Next: How to find out PVs preventing SSCAN from running? Li, Ji via Tech-talk
Prev: RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Next: Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
