Subject: Re: Archive appliance on RHEL8
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Wed, 4 Aug 2021 18:30:48 +0000
It might help to see these log lines from the mgmt's arch.log. Specifically, we should see something like so
2    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
2    [main] INFO  org.epics.archiverappliance.config.DefaultConfigService  - Obtained my identity from environment variable test-arch
2    [main] INFO  org.epics.archiverappliance.config.DefaultConfigService  - My identity is test-arch
3    [main] INFO  org.epics.archiverappliance.config.AppliancesList  - appliances.xml file specified in the environment as /scratch/.../single_VM_appliances.xml
11   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is test-arch and my mgmt URL is http://test-arch.slac.stanford.edu:17665/mgmt/bpl
The identity, "Obtained my identity from environment variable" comes from the environment variable ARCHAPPL_MYIDENTITY. This should match an appliance definition in the appliances.xml "appliances.xml file specified in the environment as /scratch/.../single_VM_appliances.xml" specified using the environment variable ARCHAPPL_APPLIANCES.
Murali
Prev: RE: Autostart with manage-procs and network mounts Smith, William via Tech-talk
Next: RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Prev: Re: Archive appliance on RHEL8 Michael Davidsaver via Tech-talk
Next: archive appliance Sinclair, John via Tech-talk
