On 8/3/21 12:21 PM, Sinclair, John via Tech-talk wrote:
> Has anyone installed the archive appliance on RHEL8?
What does your appliances.xml look like?
> I can't get past the following error:
> Pointing a browser at http://localhost:17665/mgmt <http://localhost:17665/mgmt> gives:
> HTTP Status 500 – Internal Server Error
> TypeStatus Report
> MessageThe config service for this installation did not start up correctly. Please check the logs for any exceptions or FATAL errors. Unable to determine applianceinfo using identity dev-ics-nnl2.ics.sns.gov <i>org.epics.archiverappliance.config.exception.ConfigException: Unable to determine applianceinfo using identity dev-ics-nnl2.ics.sns.gov at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:255) at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:44) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4763) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5232) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:755) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729) at
> org.apache.catalina.core.StandardHost.addChild(StandardHost.java:695) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1016) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1903) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) </i>
> DescriptionThe server encountered an unexpected condition that prevented it from fulfilling the request.
> I have tried tomcat 8 and 9, both with java 8 and 11 and I get a similar message. For tomcat 9, the message involves more functions but the problem is the same.
> Thanks,
> John Sinclair
- Archive appliance on RHEL8 Sinclair, John via Tech-talk
Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Sinclair, John via Tech-talk
<2021>
2025
2026
Re: Archive appliance on RHEL8 Shankar, Murali via Tech-talk
<2021>
2025
2026
