Subject: Re: ADURL with Axis PTZ network camera
From: Katie Matusik via Tech-talk <[email protected]>
Date: Mon, 9 Aug 2021 10:28:47 -0700
Hi Mark,
That one works.
-Katie
On Mon, Aug 9, 2021 at 9:58 AM Mark Rivers <[email protected]> wrote:
Hi Katie,
What happens if you use this URL?  Peter Heesterman recently told me this was working from ADURL.
http://202.245.13.81/cgi-bin/mjpeg
Sent: Monday, August 9, 2021 11:31 AM
Hi Mark,
I'm using ADSupport R6-2-1 and I get the same error if %size=1 is removed from the url.
Thanks!
Katie
On Fri, Aug 6, 2021 at 8:16 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
What version of ADSupport are you using?
What happens if you remove the &size=1 from the end of the URL?
Sent from my iPhone
On Aug 6, 2021, at 5:27 PM, Katie Matusik via Tech-talk <[email protected]> wrote:
Hi all,
I'm running epics base 3.15.9 with areaDetector R3-11 and using ADURL to try to grab images from an AXIS M5065 PTZ Network Camera. The URL of the image feed is http://10.0.1.50/view/view.shtml?id=68&imagepath=%2Fmjpg%2Fvideo.mjpg&size=1 and I can see the live feed in the browser but I get an error message in the ADURL IOC that states "error reading URL="" No decode delegate for this image format (/tmp/gm48Qkon) reported by ../constitute.c:1534 (GmReadImage)". Any help is appreciated, thank you!
-Katie
[https://static1.squarespace.com/static/56de1f4a2fe1318cf0aacc98/t/5d9e0fa57996446a078a8e1a/1570639781104/Logo_gmail_small.png?format=300w]
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Image removed by sender.
Katie Matusik
Systems Engineer
ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Re: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
RE: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Prev: RE: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Next: Re: archiver appliance error Shankar, Murali via Tech-talk
Next: RE: ADURL with Axis PTZ network camera Heesterman, Peter J via Tech-talk
