Subject: RE: ADURL with Axis PTZ network camera
From: "Heesterman, Peter J via Tech-talk" <[email protected]>
To: Katie Matusik <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 9 Aug 2021 17:41:39 +0000
Hi Katie,
I’m not familiar with that particular camera model.
I’ve been trying to locate one from http://www.insecam.org/en/bytype/Axis/, but the site only selects by manufacturer, and not by model type.
In the web browser view (I’m using Firefox for this), can you right click on the image and select ‘copy image link”.
Does this give a different URL?
If so, can you try that instead?
Many camera types emit a compound image which cannot be parsed by the ADURL module.
Cheers,
Peter.
From: Tech-talk <[email protected]> On Behalf Of Katie Matusik via Tech-talk
Sent: 09 August 2021 17:31
Subject: Re: ADURL with Axis PTZ network camera
Hi Mark,
I'm using ADSupport R6-2-1 and I get the same error if %size=1 is removed from the url.
Thanks!
Katie
On Fri, Aug 6, 2021 at 8:16 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
What version of ADSupport are you using?
What happens if you remove the &size=1 from the end of the URL?
Sent from my iPhone
On Aug 6, 2021, at 5:27 PM, Katie Matusik via Tech-talk <[email protected]> wrote:
Hi all,
I'm running epics base 3.15.9 with areaDetector R3-11 and using ADURL to try to grab images from an AXIS M5065 PTZ Network Camera. The URL of the image feed is http://10.0.1.50/view/view.shtml?id=68&imagepath=%2Fmjpg%2Fvideo.mjpg&size=1 and I can see the live feed in the browser but I get an error message in the ADURL IOC that states "error reading URL="" No decode delegate for this image format (/tmp/gm48Qkon) reported by ../constitute.c:1534 (GmReadImage)". Any help is appreciated, thank you!
-Katie
[https://static1.squarespace.com/static/56de1f4a2fe1318cf0aacc98/t/5d9e0fa57996446a078a8e1a/1570639781104/Logo_gmail_small.png?format=300w]
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Re: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Prev: Re: archiver appliance error Shankar, Murali via Tech-talk
Next: Phoebus image widget info Siddons, David via Tech-talk
Prev: Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Next: Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
