Subject: Re: Phoebus image widget info
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Kasemir, Kay" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 9 Aug 2021 19:05:05 +0000
Hi Kay,
  OK, thanks. That tells me enough I think. I'll look at the example.
Pete.
Sent: Monday, August 9, 2021 2:52 PM
To: EPICS Tech Talk <[email protected]>; Siddons, David <[email protected]>
Hi:
There's really just the example display, which demos the cursor PVs.
A cursor info PV is updated with the current mouse position in the image and the pixel value at that location.
When the crosshair is active, the position of the crosshair is used instead of the current mouse position, meaning you have to 'click' in the image instead of just moving the mouse around.
The location is reported both in X/Y axis coordinates and as integer offsets within the image.
The value is of type VTable and can be displayed directly in a table widget (useful for test/demo), or used in a script (if you actually want to do something with the data).
While the VTable has more detail, it's somewhat inconvenient for the larger EPICS ecosystem. The Cursor X and Y PVs can be set to plain PVs, which will be updated via channel access. We use that to send the image location that the user clicks to some IOC, which then for example moves motors to position a sample at the clicked location.
-Kay
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Monday, August 9, 2021 2:43 PM
Subject: [EXTERNAL] Phoebus image widget info
Is there any documentation for the image widget for Phoebus? In particular, it has three entries relating to a cursor:
Cursor info PV
Cursor X PV
Cursor Y PV
Can anyone tell me how they are supposed to be used?
Pete.
Phoebus image widget info Siddons, David via Tech-talk
Re: Phoebus image widget info Kasemir, Kay via Tech-talk
Prev: Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Next: RE: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Prev: Re: Phoebus image widget info Kasemir, Kay via Tech-talk
Next: Archiver getDataAtTime and getData endpoints have a timestamp discrepancy De La Paz, Elena via Tech-talk
